Author Topic: Does anyone know how to wire a mh ballast multi tap to 240 volt?  (Read 3458 times)
ramdude2014
Does anyone know how to wire a mh ballast multi tap to 240 volt? « on: August 05, 2019, 05:57:32 PM » Author: ramdude2014
Need help understanding how to use the 240 volt option on my multi tap mh ballast... any help?
Next stop gate T17!
Re: Does anyone know how to wire a mh ballast multi tap to 240 volt? « Reply #1 on: August 05, 2019, 08:12:26 PM » Author: sol
You would connect the 240v wire to one leg of your circuit and the common to the other leg. Make sure you properly cap the unused leads and use a double pole switch for safety.
ramdude2014
Re: Does anyone know how to wire a mh ballast multi tap to 240 volt? « Reply #2 on: August 05, 2019, 08:31:01 PM » Author: ramdude2014
Was thinking that but wasn't sure. Thank you
Next stop gate T17!
Re: Does anyone know how to wire a mh ballast multi tap to 240 volt? « Reply #3 on: August 05, 2019, 08:34:18 PM » Author: sol
You're welcome.
streetlight98
Mike McCann
Re: Does anyone know how to wire a mh ballast multi tap to 240 volt? « Reply #4 on: August 11, 2019, 06:23:39 PM » Author: streetlight98
This is why the second supply connection is called "common" and not "neutral". It's a neutral for 120V and 277V, but it's a hot for 208V and 240V. The terms "common" and "neutral" are not necessarily the same thing. Think rectangle/square scenario.
