Author Topic: Will running a dead incandescent on a 50W HPS ballast cause it to explode?  (Read 8267 times)
Fluorescent05
Zack
Will running a dead incandescent on a 50W HPS ballast cause it to explode? « on: September 28, 2019, 04:30:44 PM » Author: Fluorescent05
Will a dead 60 watt incandescent explode if ran on a 50 watt high pressure sodium ballast?
High Intensity
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #1 on: September 28, 2019, 04:52:43 PM » Author: High Intensity
No, i've tried the same thing but with a 150w HPS ballast and nothing happens.
Fluorescent05
Zack
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #2 on: September 28, 2019, 04:57:07 PM » Author: Fluorescent05
Does it arc?
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #3 on: September 28, 2019, 05:20:41 PM » Author: Ash
Are the fuses in the stem blown open ?
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #4 on: September 28, 2019, 05:40:09 PM » Author: sox35
Just curious as to why you would want to do this  ???
High Intensity
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #5 on: September 28, 2019, 06:14:53 PM » Author: High Intensity
Does it arc?
Nope, it does nothing.
fluorescent lover 40
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #6 on: September 28, 2019, 06:20:57 PM » Author: fluorescent lover 40
He could be just be experimenting. I've done it in the past and nothing happens though. On a PSMH ballast, things get interesting. A 70w ballast can cause a 60w lamp to arc all the way to the base. A couple of years ago, I put a dead Westinghouse 100w T19 lamp on a 320w PSMH ballast (regret it), and within two minutes of arcing, it exploded. I still have it's cool blue glass insulated base though as a memory of it.
« Last Edit: September 28, 2019, 06:22:56 PM by fluorescent lover 40 » Logged
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #7 on: September 28, 2019, 06:23:08 PM » Author: sox35
He could be just be experimenting. I've done it in the past and nothing happens though. On a PSMH ballast, things get interesting. A couple years ago, I put a dead Westinghouse 100w T19 lamp on it (regret it), and within two minutes of arcing, it exploded. I still have it's cool blue glass insulated base though as a memory of it.
Ah, ok. I suppose knowing Photonicinduction's antics, I shouldn't be surprised at someone wanting to blow stuff up ;D :D
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #8 on: September 28, 2019, 06:36:21 PM » Author: HomeBrewLamps
250 Watt HPS ballasts and upwards are able to nuke lamps. But a 60 watt in a dead won't explode. It will arc internally change colors and die. If you want a good explosion put some automotive bulbs on an HPS ballast.
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #9 on: September 28, 2019, 06:40:31 PM » Author: Mandolin Girl
He does do some crazy sh... stuff.!! We can't wait to meet him later this year.!!  ;D 8)
Fluorescent05
Zack
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #10 on: September 28, 2019, 07:12:53 PM » Author: Fluorescent05
When I put it on the 50 watt HPS ballast, it just arced inside where the wires come out of the pinch seal near the base. It looked pretty cool.
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #11 on: September 28, 2019, 08:08:19 PM » Author: HomeBrewLamps
Take a look at one of my more recent gallery posts lol.
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #12 on: September 28, 2019, 08:12:53 PM » Author: fluorescent lover 40
Will he give both of you high-voltage transformers so the both of you can blow things up? ;D Cool that you're meeting him! :)
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #13 on: September 28, 2019, 09:47:13 PM » Author: wide-lite 1000
Somewhere I have a 70 w HPS bollard light with a F-can style ballast that says it can also run a equivalent wattage incandescent lamp. Years ago I actually tried it and it worked fine as a matter of fact I've personally seen low wattage HPS fixtures relamped with incandescents frequently around here with no ill effects.
Fluorescent05
Zack
Re: Will running a dead incandescent on a 50W HPS ballast cause it to explode? « Reply #14 on: September 28, 2019, 10:30:38 PM » Author: Fluorescent05
Your ballast probably means for a 120v standby lamp when the voltage is not 120. Is it multitap?
