Author Topic: Dead incandescent lamps on car HID ballasts?  (Read 3025 times)
Fluorescent05
Zack
Dead incandescent lamps on car HID ballasts? « on: September 29, 2019, 09:32:17 PM » Author: Fluorescent05
Will this cause the lamps to explode?
Re: Dead incandescent lamps on car HID ballasts? « Reply #1 on: September 30, 2019, 12:40:48 AM » Author: Medved
Probably not (assume quality ballast), because those have to be very picky on lamp behavior, so sill shut down before the arcing would do anything...
Re: Dead incandescent lamps on car HID ballasts? « Reply #2 on: September 30, 2019, 01:05:32 AM » Author: dor123
What about aftermarket car MH ballasts without protections?
Re: Dead incandescent lamps on car HID ballasts? « Reply #3 on: September 30, 2019, 01:43:55 AM » Author: Medved
I doubt there are any. The thing is in order for the ballast to work at least somehow and to be cheap at the same time, you have to use one of the dedicated ICs as their controller. And these already contain the protection logic, it is tyere and not designed to be disabled.
And because fooling this logic by the circuit around makes the circuit more complex and expensive than simply wiring it in, guess what approach the cheepee maker will use...
