Author Topic: Can I replace a regular switch with a fan switch?  (Read 3430 times)
CreeRSW207
Can I replace a regular switch with a fan switch? « on: November 28, 2019, 06:10:14 PM » Author: CreeRSW207
My ceiling fan has a normal switch wired to it I’m wondering if I can change the regular switch with the fan switch.
Owner of Top Cat Enterprises
Belmont NH, Oahu HI
US Army
See the value in anything and everything
Re: Can I replace a regular switch with a fan switch? « Reply #1 on: November 28, 2019, 06:22:37 PM » Author: Cole D.
You can, you can put the pull chain switch on the fan on high speed, and then use the wall switch to change the speeds. That's how the ceiling fans in my house are set up.
Just don't use a dimmer switch with it, because it can cause damage to the motor.
CreeRSW207
Re: Can I replace a regular switch with a fan switch? « Reply #2 on: November 28, 2019, 06:58:24 PM » Author: CreeRSW207
Would I be able to use a switch like this?
Belmont NH, Oahu HI
US Army
Re: Can I replace a regular switch with a fan switch? « Reply #3 on: November 28, 2019, 07:49:33 PM » Author: Cole D.
I have that same switch in my bedroom. Slider for the 3 speeds and off and then the switch for the light.
