Author Topic: BBQ igniters  (Read 4019 times)
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
BBQ igniters « on: December 31, 2008, 11:42:13 AM » Author: Foxtronix
I know that BBQ igniters can give an high voltage kick, but how many volts exactly?
form109
Re: BBQ igniters « Reply #1 on: December 31, 2008, 12:14:40 PM » Author: form109
im guessing somewhere around 4,000 volts?
Mercury Man
Re: BBQ igniters « Reply #2 on: December 31, 2008, 03:14:23 PM » Author: Mercury Man
What is it about the BBQ ignitor that actually causes an HPS lamp to light up on an MV ballast?  I've always been curious about why that works.
form109
Re: BBQ igniters « Reply #3 on: December 31, 2008, 06:20:12 PM » Author: form109
i believe bar-b-q ignitors use the principal of pizeo electricity,that is crystals release an electric pulse when compressed.
Foxtronix
Re: BBQ igniters « Reply #4 on: December 31, 2008, 08:39:17 PM » Author: Foxtronix
Form109 is right. I have 6 BBQ igniters I found here and there. I have one with a rotating button! I love these things.
Re: BBQ igniters « Reply #5 on: December 06, 2017, 01:22:37 AM » Author: HomeBrewLamps
How many cycles can a piezio Electric Ignitor handle before failing?
Re: BBQ igniters « Reply #6 on: December 06, 2017, 03:51:16 AM » Author: Medved
Depends, how well its mechanic is made.
The same crystals (or better to say the piezo ceramic slugs, they are usually some form of polycrystalline ceramic) alone are used for applications with 1+M cycles as generators (transfer mechanical movement into electricity) and with 1+G cycle life as actuators (transform an electrical pulse into mechanical movement), but the consumer stove/grill/lighter ignitors have just too flimsy mechanical design, which is in many cases overloading the crystals with uneven pressure, uncontrolled shocks and so on, so either  the mechanics itself wears or the crystal breaks after just few 100's cycles....
