Author Topic: Guys, I need your help!!  (Read 4249 times)
Seth11
13 watt Color CFLs!
Guys, I need your help!! « on: March 19, 2020, 06:00:16 PM » Author: Seth11
II’m having trouble with my 4xF40 strip, when I ground the fixture and only run one ballast it works fine, but when I wire both ballasts in circuit, it trips the breaker, the fixture doesn’t have a dedicated spot on it for a grounding screw so I usually placed the ground wire underneath the ballast. I did swap out one of the ballast that might be questionable but still having problems with it tripping the breaker. I’m not sure if there’s a ground fault or maybe the ground wire isn’t supposed to be placed under the ballast. One more thing I’d like to mention is that when I remove the ground from the fixture, works fine without tripping the breaker. Any advice would be appreciated!
Say NO to LEDS!!
Seth11
13 watt Color CFLs!
Re: Guys, I need your help!! « Reply #1 on: March 19, 2020, 06:52:39 PM » Author: Seth11
Someone please help!
Say NO to LEDS!!
fluorescent lover 40
Re: Guys, I need your help!! « Reply #2 on: March 19, 2020, 07:21:17 PM » Author: fluorescent lover 40
Did you try replacing both ballasts?
Seth11
13 watt Color CFLs!
Re: Guys, I need your help!! « Reply #3 on: March 19, 2020, 08:14:52 PM » Author: Seth11
Fixed the problem! Turns out, it was bare copper wire poking out of the cardboard piece of one of the sockets. I trimmed down the wire and that took care of it!!  ;D ;D ;D
Say NO to LEDS!!
Re: Guys, I need your help!! « Reply #4 on: March 19, 2020, 08:16:08 PM » Author: fluorescent lover 40
Fixed the problem! Turns out, it was bare copper wire poking out of the cardboard piece of one of the sockets!
Awesome that it was a simple issue and not one of the ballasts.
Re: Guys, I need your help!! « Reply #5 on: March 19, 2020, 09:18:07 PM » Author: wide-lite 1000
The easiest fixes are sometimes the hardest to find ! :lol:
CreeRSW207
Re: Guys, I need your help!! « Reply #6 on: March 20, 2020, 08:56:28 AM » Author: CreeRSW207
That's like the time I changed an outlet powered by a switch to a table lamp, after it was changed the lamp stayed on instead of following the switch command. All that needed to happen was to pull off a little tab on the side! :lol: :lol:
Owner of Top Cat Enterprises
Belmont NH, Oahu HI
US Army
See the value in anything and everything
Re: Guys, I need your help!! « Reply #7 on: March 20, 2020, 06:16:34 PM » Author: sox35
That sounds scary to me...  :o
Re: Guys, I need your help!! « Reply #8 on: March 20, 2020, 07:01:12 PM » Author: sox35
Cardboard sockets..? I'll say  :o
Re: Guys, I need your help!! « Reply #9 on: March 20, 2020, 09:12:49 PM » Author: joseph_125
Yeah the cardboard backing is very common with a lot of older fluorescent sockets here
What doesn't help is that a lot of fluorescents use a push in connection too so when you strip the wire past the recommended 3/8" there's a chance it'll poke out. I believe if you strip to 3/8" the insulation will prevent the wire from poking too far out.
