Author Topic: What's the difference?  (Read 2951 times)
RadxD461
What's the difference? « on: July 21, 2020, 09:50:43 AM » Author: RadxD461
What's the difference of a high-pressure mercury vapor light bulb and a standard mercury vapor light bulb? Could you run a high pressure mercury vapor light bulb on a standard mercury vapor ballast?
Re: What's the difference? « Reply #1 on: July 21, 2020, 10:17:05 AM » Author: dor123
Both are two different names of the same lamp.
Re: What's the difference? « Reply #2 on: July 21, 2020, 11:58:37 AM » Author: sox35
The earliest designs of mercury lamps were medium pressure, then the high pressure (MB) versions were developed, which were more versatile, smaller and could operate in any position. The original medium pressure (MA) lamps could only be operated vertically base up, although they could be run horizontally with a magnetic arc deflector.
They are electrically identical, so can be run on the same gear.
