Author Topic: LPS bulb that works in a MV fixture?  (Read 8938 times)
KJ7BZC
115Vac 60Hz Mains Power
UC59tGoPqY4OgWbqmCie2IvA KJ7BZC
LPS bulb that works in a MV fixture? « on: August 10, 2020, 05:28:18 PM » Author: KJ7BZC
Hi, I just picked up my first lamps in my collection today. They are the 175 watt Mercury vapor yardblaster lights that are seen just about everywhere. Anyways my favorite kind of lights are MV and LPS, and I know that there are HPS bulbs that are compatible with MV fixtures, but do you guys know of any LPS bulbs that are compatible with the 175 watt MV ballast? I would like to have a LPS fixture sometime but I was just wondering if there was a way to use one of these as LPS by default. Also if you happen to know the model of the HPS bulb I mentioned earlier that would be great as well. Thanks!
Researching ripple control systems and developing my own. Feel free to reach out with any questions about them.
Bulbman256
Kick the AI scrapers off LG
Bulbman256
Re: LPS bulb that works in a MV fixture? « Reply #1 on: August 10, 2020, 07:20:48 PM » Author: Bulbman256
Im pretty sure that is electrically impossible with a normal sox lamp and I think no company took the effort to design a lamp that was electrically compatible with an mv ballast. Besides most people didn't retrofit mv with sox they replaced the fixture with hps or led or used one of those hps retrofit lamps.
KJ7BZC
Re: LPS bulb that works in a MV fixture? « Reply #2 on: August 10, 2020, 10:08:10 PM » Author: KJ7BZC
Alright, I'm sure there are HPS bulbs that work for it because I've seen them. However I severely doubted the existence of a compatible SOX bulb for it, I was just checking if there might have been one.
Metal Halide Boy
Re: LPS bulb that works in a MV fixture? « Reply #3 on: August 13, 2020, 08:00:24 AM » Author: Metal Halide Boy
[/quote
There ARE HPS retrofits for MV. See here .
Lightingguy1994
Re: LPS bulb that works in a MV fixture? « Reply #4 on: August 13, 2020, 08:44:16 PM » Author: Lightingguy1994
The only combo that is even kinda possible is SOX18 on a F32T8 electronic instant start ballast which does work well
Re: LPS bulb that works in a MV fixture? « Reply #5 on: August 14, 2020, 03:33:27 AM » Author: Medved
The question was about LPS, not HPS...
The thing is, LPS needs rather high voltages and lower currents, which is far off what the optimum for the high pressure lamps is.
The high pressure lamps have rather similar ranges, so they could be designed to work on the same ballast characteristics, with just the ignition added to the HPS lamps - either an extra capacitive electrode (a wire or conductive stripe around the arctube, connected to one terminal usually via a bimetal switch,... - popular by Tesla), a small HV pulser integrated into the lamp base (e.g. FEC device popular by Iwasaki, or a starter like switch popular with e.g. Osram,...) or modified fill mix for easier ignition on expense of lower efficacy (or a combination).
UChBXesrxSalDTp79uMtfDvA
Re: LPS bulb that works in a MV fixture? « Reply #6 on: October 14, 2020, 06:56:20 PM » Author: WorldwideHIDCollectorUSA
I believe a 200w SLI/H lamp from the UK is a LPS lamp that can run pretty well on a 175w mercury ballast because a 200w SLI/H lamp needs 145v 1.55a to operate while a 175w mercury bulb needs 130v 1.5a to operate. The thing you would need to do is to move the 175w mercury ballast to a F30T12 or a F25T8 fixture and you would use a Philips BodyTone starter rated for 120w-180w fluorescent tubes or a Philips BodyTone starter for 180w-225w tubes.
Here is a link to buy SLI/H lamps here:
http://www.cp-lighting.co.uk/Double-Ended-Linear-Sodium-Lamp-200W-900mm-Gold-G13-Cap-1700K
« Last Edit: October 14, 2020, 07:00:04 PM by WorldwideHIDCollectorUSA » Logged
Lightingguy1994
Re: LPS bulb that works in a MV fixture? « Reply #7 on: October 14, 2020, 07:11:41 PM » Author: Lightingguy1994
A 200w SLI lamp will not fit into a yardblaster. The poster wanted to retrofit their yard blaster lights.
Re: LPS bulb that works in a MV fixture? « Reply #8 on: October 14, 2020, 07:30:28 PM » Author: WorldwideHIDCollectorUSA
A mogul to medium socket, a medium socket to outlet adapter and a single lamp F25T8 or F30T12 striplight could be used where the yardblaster is remotely ballasting the striplight to power the 200w SLI/H bulb.
Re: LPS bulb that works in a MV fixture? « Reply #9 on: October 15, 2020, 01:16:52 AM » Author: Medved
Operating arc voltage is not the only thing to match for the ballast/lamp combination to work. You need the ballast to have sufficient OCV to operate the discharge even in modes where e.g. the electrodes had not warmed up yet. And there the 220V is enough for a probe start MV, but way insufficient for the LPS.
But you wont damage anything by just trying it out - worst case it just will be unreliable for starting...
KJ7BZC
Re: LPS bulb that works in a MV fixture? « Reply #10 on: October 15, 2020, 02:22:24 PM » Author: KJ7BZC
At this point I think I am going to just get a proper ballast and such for the SOX bulb. Considering I don't need it to be super bright I am going to use a lower wattage bulb, that would also help it not stick out of the fixture as much. Maybe a 35W, but I can't seem to find them for a low price, that seems to be something common with SOX in general.
Re: LPS bulb that works in a MV fixture? « Reply #11 on: October 15, 2020, 10:18:03 PM » Author: WorldwideHIDCollectorUSA
By the way, a SLI/H linear LPS lamp has a lower OCV than a typical SOX lamp. As a result, it can be ignited on preheat/switchstart gear such as the 175w MV ballast and the Philips Bodytone starter. Other members here have been able to get SLI/H lamps to ignite using preheat/switchstart gear.
Re: LPS bulb that works in a MV fixture? « Reply #12 on: October 16, 2020, 02:53:48 AM » Author: Medved
"...lamp has a lower OCV than..."
Lamp does not <have> OCV, ballast has.
A lamp <needs> certain OCV, if the ballast does not provide it, it wont start or run properly.
It is true once you may preheat the filaments there, that is a huge difference, as there is no glow discharge part at all, so no need to support it. But aren't the linear LPS horizontal only?
Re: LPS bulb that works in a MV fixture? « Reply #13 on: October 16, 2020, 02:57:29 AM » Author: WorldwideHIDCollectorUSA
Actually yes. I was imagining that the yardblaster would be used as a remote ballast and a 3 foot fluorescent striplight would be used to hold the lamp in place. What I meant by lower OCV was the lower starting voltage of the lamp.
Re: LPS bulb that works in a MV fixture? « Reply #14 on: October 17, 2020, 09:52:57 PM » Author: funkybulb
 Actually there is such thing 35 watt LPS yard blaster.  Doubled up refractor glued together
