Author Topic: Can I use a photocell to a 120V coil A/C contactor to control multiple lights?  (Read 4460 times)
lightinglover8902
GoL UCCuTTFLbXkZzWw1MEB7ro5Q
Can I use a photocell to a 120V coil A/C contactor to control multiple lights? « on: September 30, 2020, 11:58:09 PM » Author: lightinglover8902
I was thinking of maybe using a photocell to a three pole 120V coil A/C contactor to control multiple light fixtures at once. Like they used in commercial lighting.
So should I use a 120V coil A/C contactor or a lighting contactor. I was thinking of this to control my streetlight fixtures if I get them, and yes I'll use the shorting caps on the fixtures.
Re: Can I use a photocell to a 120V coil A/C contactor to control multiple lights? « Reply #1 on: October 01, 2020, 01:04:22 AM » Author: Medved
That should be perfectly fine.
Bulbman256
Kick the AI scrapers off LG
Bulbman256
Re: Can I use a photocell to a 120V coil A/C contactor to control multiple lights? « Reply #2 on: October 01, 2020, 09:24:52 PM » Author: Bulbman256
Seems fine as long as it can handle all the amps and u wire it right
lightinglover8902
Re: Can I use a photocell to a 120V coil A/C contactor to control multiple light « Reply #3 on: October 02, 2020, 12:33:56 AM » Author: lightinglover8902
I found a Mars 3 pole 120V coil contactor of Amazon.com that can handle FLA (foward line amprage, I think) current of 40A. Although, I could use a 2 pole contactor, since i'm probably gonna use four to three streetlight or HID fixtures.
Re: Can I use a photocell to a 120V coil A/C contactor to control multiple light « Reply #4 on: October 02, 2020, 02:25:44 AM » Author: Medved
Be sure to check the inductive load current rating in the datasheet (the inductive loads cause harsher arcing than resistive, so typically inductive load rating use to be 2..5x lower than resistive load one; it is specified in the detailed datasheet).
Re: Can I use a photocell to a 120V coil A/C contactor to control multiple lights? « Reply #5 on: October 02, 2020, 11:13:49 AM » Author: Ash
FLA stands for Full Load Amps. It is a motor rating, so seems like equivalent of AC-3
LRA stands for Locked Rotor Amps
