Author Topic: Can you tell the difference between a 50hz and 60hz flash patterns on video?  (Read 3896 times)
Can you tell the difference between a 50hz and 60hz flash patterns on video? « on: October 16, 2020, 12:48:22 PM » Author: WorldwideHIDCollectorUSA
I wonder if anybody who has experience watching lighting videos can see the difference between 50hz and 60hz flash patterns.
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #1 on: October 16, 2020, 12:57:01 PM » Author: Mandolin Girl
I can't speak from personal experience, but being able to tell the difference between 50 or 60 flashes per second would require measuring equipment and not something that could be done with the naked eye.
« Last Edit: October 16, 2020, 02:03:03 PM by Mandolin Girl » Logged
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #2 on: October 23, 2020, 12:59:56 AM » Author: WorldwideHIDCollectorUSA
In my experience, 60hz flicker on video appears as stationary dark bands while 50hz flicker on video shows fleeting dark bands.
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #3 on: October 23, 2020, 03:09:37 AM » Author: Medved
If you know your frame frequency, it hasn't been altered by any conversions, the strobe pattern should tell it. But very often the camera sensor does not operate at the same frame rate as it is then stored in the file, so it becomes hard to tell then, all the compression and conversions make a ton of artifacts, which then drown the effects you are looking for.
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #4 on: October 23, 2020, 03:37:11 AM » Author: WorldwideHIDCollectorUSA
The slow moving and stationary dark bands is indicative of a 60hz flash pattern from my observation while fleeting dark bands indicate a 50hz flash pattern. This is what I have observed when watching lighting videos that were filmed in various parts of the world.
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #5 on: October 23, 2020, 03:37:28 AM » Author: dor123
Most digital cameras, capture videos at 30FPS and 60FPS, even if their video system is set to PAL and not NTSC. But there are some video cameras that can see 25FPS and 50FPS, there the 100hz and 50hz flickering would be stationary lines and not moving lines
« Last Edit: October 23, 2020, 03:49:18 AM by dor123 » Logged
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #6 on: October 23, 2020, 03:46:22 AM » Author: WorldwideHIDCollectorUSA
Here is a lighting video filmed with 60hz flicker:
https://youtu.be/oDCe4en5sVg
Here is a lighting video filmed with 50hz flicker:
https://youtu.be/OWeqxFCnJ2A
These flash patterns are what I commonly see on youtube.
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #7 on: October 23, 2020, 03:55:54 AM » Author: dor123
Both videos are captured at 60FPS, hence the moving lines at the 50hz videos. If "The -Y&Z-" would have a video camera that can capture 50FPS, the lines would be the same as in the 60hz video, not moving.
This is all related to the matching between the flickering frequency and the camera frames per second shooting. so the lines won't move if 50hz or 100hz are captured by 25FPS or 50FPS, and 60hz or 120hz by 30FPS or 60FPS, but will move if 50hz captured by 30FPS and 60FPS and 60FPS by 25FPS and 50FPS.
Here is a 50hz video that was captured at 50FPS: https://www.youtube.com/watch?v=sPzhW1LpTqM
« Last Edit: October 23, 2020, 03:58:13 AM by dor123 » Logged
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #8 on: October 23, 2020, 04:08:52 AM » Author: WorldwideHIDCollectorUSA
I can tell that the video is 50hz due to the sound of the ballast hum. Do you know of any 60hz videos filmed at 50FPS?
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #9 on: October 23, 2020, 04:14:50 AM » Author: dor123
I don't know about videos of 50/100hz lighting that being captured at 30/60FPS.
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #10 on: October 23, 2020, 07:14:34 AM » Author: Medved
Most monitor interfaces are based on the 60Hz, so are many camera ones.
But these effects are known and generally treated as an evil, so many systems use measures to specifically suppress them (physical camera frame rate, combined with the postprocessing software). And these often works to eliminate the effects, but sometimes create a plethora of new ones.
And because these systems use to be designed to work with both 50 and 60Hz, they may easily smear the difference (e.g. use the physical camera frame rate at 55Hz and suppress the 5Hz beat frequency in the software), or make the resulting effects (the 5Hz) the same for both 50 and 60Hz flicker.
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: Can you tell the difference between a 50hz and 60hz flash patterns on video? « Reply #11 on: October 23, 2020, 11:42:46 PM » Author: Binarix128
Most normal users use their cameras with automatic shutter speed and automatic flicker compensation, so 50Hz and 60Hz can look the same or don't even show.
