Author Topic: What happens if you try to operate a CWA ballast without a capacitor?  (Read 2985 times)
UChBXesrxSalDTp79uMtfDvA
What happens if you try to operate a CWA ballast without a capacitor? « on: October 17, 2020, 03:34:38 AM » Author: WorldwideHIDCollectorUSA
I would be interested in knowing what happens to HID bulbs if they are on a CWA ballast that does not have a capacitor?
Re: What happens if you try to operate a CWA ballast without a capacitor? « Reply #1 on: October 17, 2020, 04:02:11 AM » Author: dor123
The lamp will be underdriven or fail to start, as CWA uses the capacitor as its ballasting component. This is similar to rapid-start fluorescent ballasts.
Re: What happens if you try to operate a CWA ballast without a capacitor? « Reply #2 on: October 17, 2020, 05:19:49 AM » Author: Medved
It will turn it into a kind of HX autotransformer. Definitely they will have lower efficiency (because the reactive power wont be compensated in primary).
It depends how exactly is the ballast designed, but most are so they underdrive the lamp (because that is what a short circuit capacitor fault would do; so they wont overheat even with the extra primary loading). But there could be ballasts which may get overheated (mainly the high efficiency ones, using unusually high value capacitor compare to other comon ballast types for the given lamp type)
Re: What happens if you try to operate a CWA ballast without a capacitor? « Reply #3 on: October 17, 2020, 09:30:13 AM » Author: sol
I believe that some HID dimming setups used CWA ballasts with two capacitors and one is switched in and out of the circuit to achieve two level dimming.
