Author Topic: Flourescent Fixture Restoration Project  (Read 3972 times)
form109
Flourescent Fixture Restoration Project « on: March 13, 2009, 08:14:29 PM » Author: form109
ok gang,here's the scoop....i plan to buy several Linear Flourescent Fixtures from a flea market...and to no suprise none are Functioning...some by Spoiled Lamps(Evident by heavy blackening of the tube)others most likely by Bad ballasts,starters,or even faulty wiring...i plan to fix them....but need advice on what brands of ballasts,lamps and starters to buy,and those to avoid,any help?
lightman64
Re: Flourescent Fixture Restoration Project « Reply #1 on: March 14, 2009, 10:57:39 AM » Author: lightman64
For ballasts get GE pre-heat ballasts- they give the blinks before startup, bulbs get sylvania or ge, and starters, well im not sure what is the best.
form109
Re: Flourescent Fixture Restoration Project « Reply #2 on: March 15, 2009, 06:23:48 PM » Author: form109
they still make Preheat Ballasts?
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: Flourescent Fixture Restoration Project « Reply #3 on: March 16, 2009, 11:49:21 AM » Author: Foxtronix
Preheat ballasts for 14-15-20W fluorescents are still made. You have probably seen many of these in my gallery.
