Author Topic: Why did SOX lamps use B22 bases?  (Read 2831 times)
UChBXesrxSalDTp79uMtfDvA
Why did SOX lamps use B22 bases? « on: October 21, 2020, 04:02:03 PM » Author: WorldwideHIDCollectorUSA
I wonder why B22 bases were used for SOX, SOI/H, and SO/H lamps and not another special base dedicated for them. One issue I might notice with using B22 bases on these LPS lamps is that someone might install a British household bulb in the fixture and it might damage the ballast or the bulb itself.
Re: Why did SOX lamps use B22 bases? « Reply #1 on: October 22, 2020, 09:56:25 AM » Author: Medved
Why not? For the bulb no one cares and the ballast is supposed to survive even a dying SOX, the incandescent can not be worse to it.
takemorepills
Re: Why did SOX lamps use B22 bases? « Reply #2 on: October 22, 2020, 11:45:42 PM » Author: takemorepills
B22 bases allow the fixture manufacturer to control lamp positioning. With LPS lamps it is desirable to have the 2 tubes in a level plane within the fixture. Using a B22 ensures that the parallel discharge tubes will be in the optimal position as all LPS lamps have the tubes clocked/oriented to the base.
Also, think about where LPS fixtures are installed. The average Joe isn't going to be relamping these with a GLS lamp. Usually only a technician would be relamping the typical LPS fixture. I also highly doubt stuffing a GLS bulb into a LPS fixture would be a catastrophe.
