Author Topic: How to mount a cobrahead to a fan pole?  (Read 2226 times)
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
How to mount a cobrahead to a fan pole? « on: January 10, 2021, 10:57:35 AM » Author: HPS_250
I have a Lasko fan stand pole that is currently not being used for anything, as the actual fan that goes with it is mounted somewhere else. Is there any way I could mount a cobrahead to it as a display pole?
CreeRSW207
Re: How to mount a cobrahead to a fan pole? « Reply #1 on: January 10, 2021, 12:45:21 PM » Author: CreeRSW207
If the pole isn’t too big you can just slide it into the slipfitter and tighten the bolts.
Owner of Top Cat Enterprises
Belmont NH, Oahu HI
US Army
See the value in anything and everything
Re: How to mount a cobrahead to a fan pole? « Reply #2 on: January 10, 2021, 02:59:18 PM » Author: HomeBrewLamps
I wouldn't recommend it, the base is too small and the poles are flimsy. I know this because I've destroyed a few. (purposely)
HPSM250R2
Re: How to mount a cobrahead to a fan pole? « Reply #3 on: January 10, 2021, 03:50:43 PM » Author: HPSM250R2
I don't think you're going to find any way to do it without it tipping over. Unless you weigh the base down with some sandbags. Even then the poles for those stand fans are so paper thin I doubt they're strong enough to even hold the fixture without bending. I used to have an arm mounted to the wall in my bedroom in my apartment like 8 years ago. Arm was screwed into a 2x4 that I had secured to the studs in the wall.
HPS_250
Re: How to mount a cobrahead to a fan pole? « Reply #4 on: January 10, 2021, 07:43:23 PM » Author: HPS_250
Thanks for the replies everyone. I will take your advice and either mount my fixture another way or keep it stored in its box. Fan poles are fairly light and may not be able to support the weight of a light fixture. I don’t want to risk anything falling over, which could result in damage to the surroundings of the pole, or even a broken glass refractor.
HPSM250R2
Re: How to mount a cobrahead to a fan pole? « Reply #5 on: January 10, 2021, 07:50:36 PM » Author: HPSM250R2
When I started collecting street lights when I lived with my parents I didn't keep any in the box. I had mine all laying against the wall in my bedroom, each with its own extension cord already connected to the terminal block ready to be fired up at all times. I don't have my own house at the moment so I have lights all over the place. Most of them are in my storage unit. I have maybe about a dozen or so left at my parents house that I need to move out. Plus I have a few in my office at work lol.
Re: How to mount a cobrahead to a fan pole? « Reply #6 on: January 13, 2021, 12:29:45 PM » Author: Mandolin Girl
The main thing to remember when mounting a lantern on a pole is that the lantern's centre of gravity is within whatever you decide to use as a base.
And that the base needs to be heavier than the lantern if possible or at least more than half its weight.
RadxD461
Re: How to mount a cobrahead to a fan pole? « Reply #7 on: January 14, 2021, 04:13:24 PM » Author: RadxD461
I have my street light on a fan Pole.
Re: How to mount a cobrahead to a fan pole? « Reply #8 on: January 15, 2021, 08:38:13 PM » Author: joseph_125
I briefly had my R47 on a base I built from a brake rotor and a 1-1/4 NPT pipe stub. See here for the picture.
