Author Topic: what is the operating temp of a 55 watt sox lamp ?  (Read 31616 times)
prawnman88
what is the operating temp of a 55 watt sox lamp ? « on: November 11, 2006, 08:04:42 PM » Author: prawnman88
i know they get warm but i have no way of really telling i have let mine run for 20 min and it was toasty do they run cooler or hotter then other hid ? thx for the help guys
p.s. im still learning
« Last Edit: November 12, 2006, 05:20:27 PM by prawnman88 » Logged
dp
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #1 on: November 12, 2006, 11:00:20 AM » Author: dp
I don't know exactly but they run cooler than other HID because they are very efficient. James Hooker would know.
lightboy90
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #2 on: March 18, 2007, 06:09:53 AM » Author: lightboy90
The operating temperature is about 150 °C.
prawnman88
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #3 on: April 15, 2007, 10:59:23 PM » Author: prawnman88
so arround 300 f ?    i know ferenheit
JECWhiz
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #4 on: April 16, 2007, 10:29:26 AM » Author: JECWhiz
I checked my calculater that can convert....a 150° C is same as 302° F so Good job Rich you were close!
prawnman88
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #5 on: April 16, 2007, 07:27:01 PM » Author: prawnman88
jayce then is that pretty hot for a light ? it is a 55 watt sox so it runs arround 300f then. what does a 1000w metal halide run at ? i had one cycling on a job i did not know it was and when i got up to the light to grab it out my gloves almost went up in flames that was the last time i did something fast and not checking the temp first :)  :-\ :o :o
JECWhiz
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #6 on: April 17, 2007, 02:17:21 AM » Author: JECWhiz
1000 watt MH is probably hotter than the sun  ;D
TVtommy
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #7 on: January 25, 2008, 07:29:26 PM » Author: TVtommy
approx 260c, i think?
FGS
Rory Mercury!
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #8 on: January 25, 2008, 07:43:47 PM » Author: FGS
How about the 18,000w HMI lamp (Single-ended.)
mr_big
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #9 on: February 01, 2008, 10:55:45 PM » Author: mr_big
How would you know, the second you touched it BOOM! ;D
FGS
Rory Mercury!
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #10 on: February 01, 2008, 11:17:12 PM » Author: FGS
With one of those no-contact thermometer. You don't have to touch anything to get a reading. Some of them have a built laser pointer.
lite_lover
Darren
GoL darren.harward
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #11 on: July 30, 2008, 12:39:54 AM » Author: lite_lover
I checked the temperature of my 55 Watt SOX lamp with a non-contact thermometer.
I ran the fixture for an hour.
  Outer glass: Base/electrode area 82C - 180F  End: 72C - 162F
  Arc tube: Cathode ends 95C - 203F  U bend: 83C - 181F
« Last Edit: November 23, 2008, 11:38:16 PM by lite_lover » Logged
The brighter the better.
form109
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #12 on: August 01, 2008, 08:00:38 PM » Author: form109
technically a low pressure sodium lamp is not a high intensity discharge lamp
1 a lps lamp opperates under low pressure.
2 a lps has a lower current glow discharge as apposed to hids which use higher current arc  discharges.
3 a lps lamp does not exibit the bright arc of a hid lamp and produces a soft glow similar to a flourescent lamp.
GE M-400A1
My Pontiac 6000 STE
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #13 on: August 13, 2008, 10:11:17 PM » Author: GE M-400A1
The LPS lamp is still considered a HID lamp.
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
form109
Re: what is the operating temp of a 55 watt sox lamp ? « Reply #14 on: August 13, 2008, 10:11:50 PM » Author: form109
depends on the way you look at it.
