Author Topic: Do 28w Preheat Ballasts Exist?  (Read 4297 times)
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
Do 28w Preheat Ballasts Exist? « on: March 08, 2023, 10:19:56 PM » Author: 108CAM
Asking this because I recently got an F28T5 cabinet light with an electronic ballast and would like to make a preheat fixture for the 28w tube.
I've never seen a preheat ballast for 28w T5 tubes and don't even know if they exist.
I probably could use an F30T8 ballast which will overdrive the tube by about 2 watts but would prefer an actual 28w ballast.
1925-2002
Bring back the AJF Zodiacs!
Re: Do 28w Preheat Ballasts Exist? « Reply #1 on: March 11, 2023, 04:40:18 AM » Author: RRK
Do you mean linear T5 HE 28W? Officially, no way, datasheet explicitly specifies HF ballast at >20kHz. Also, this lamp runs with low current like old school F8T5 etc tubes at 170mA, but at unusually high voltage around 166V. So it probably will not  stabilize when run from 230V line. If I'd absolutely want to run this at 50Hz, I would hack an autotransformer to about 300VAC and use some mix of ballast chokes with a suitable impedance. Standard starters won't work with such high tube voltage, but two starters in series or a hacked electronic starter may. Electrodes on this tube may be not optimized for preheat current. Also the lifetime will be definitely hit.
« Last Edit: March 11, 2023, 04:58:58 AM by RRK » Logged
Re: Do 28w Preheat Ballasts Exist? « Reply #2 on: March 11, 2023, 01:28:37 PM » Author: Medved
No, it won't be 2 W, but it could be well above that.
Plus the electrodes in these modern T5 (HE and HO) lamps do not handle the low frequency well. When their design was developed while optimizing the design of these lamps, the 50Hz ballast compatibility was just "thrown under the bus" in order to get the extra efficacy...
108CAM
Re: Do 28w Preheat Ballasts Exist? « Reply #3 on: March 11, 2023, 04:57:17 PM » Author: 108CAM
So I'd be better off using something like this Osram Quicktronic multi wattage ballast which is designed for fluorescent tubes and CFL lamps between 26w and 42w.
https://media.discordapp.net/attachments/770526034201411586/1084231557360910339/IMG_4081.jpg?width=781&height=586
The specs don't specifically say that it's compatible with F28T5 tubes but am assuming it will work
1925-2002
Re: Do 28w Preheat Ballasts Exist? « Reply #4 on: March 12, 2023, 03:52:38 AM » Author: RRK
Will grossly overdrive your tube, as these lamps are high-current CFL running at 320 mA!
Re: Do 28w Preheat Ballasts Exist? « Reply #5 on: March 13, 2023, 12:43:57 AM » Author: xmaslightguy
I once managed to run a F54T5 HO lamp on a F40T12 RS ballast. (had a bit of trouble starting & was a kinda flickery til it warmed up, but ran fine after that)
Lamp current is the same for a T5 HO and a F40T12, but the F54 really needs a higher voltage to start & run reliably (A F39T5 woulda been a better/closer match for that ballast .. but it was only a test not something I intended to put in use)
UChBXesrxSalDTp79uMtfDvA
Re: Do 28w Preheat Ballasts Exist? « Reply #6 on: April 11, 2023, 10:59:49 PM » Author: WorldwideHIDCollectorUSA
Actually, Vossloh Schwabe made some HX autotransformer preheat fluorescent tubes for HE T5 fluorescent tubes:
http://www.allthingslighting.co.uk/atl/albums/userpics/10056/VS_KVG-Starter-System_2012_GB.pdf
Re: Do 28w Preheat Ballasts Exist? « Reply #7 on: April 11, 2023, 11:32:51 PM » Author: RRK
Interesting find!
Two points:
They never mention 28W HE tubes.
They probably mean standard T5 tubes are not compatible, a special series named T5 ECO SAVER LONG LIFE is suitable.
Current mA 0.20 - is hilarious. Anyone proofread this? Ground leaks?  ;)
VS probably tried to find a market in special application lights in the wake of EC prohibition on magnetics.
Interesting that VS was acquired by Panasonic. I did not know....
BTW my idea to run 28W tube with preheat was spot on - an autotransformer + a special choke + a hacked electronic starter - exactly how VS did it, too.
« Last Edit: April 12, 2023, 12:30:49 AM by RRK » Logged
Re: Do 28w Preheat Ballasts Exist? « Reply #8 on: April 12, 2023, 12:18:14 AM » Author: RRK
Googling on that topic shows that magnetic ballasts for T5 were widely discussed in ~2011. One particulary interesting idea is here http://hub.hku.hk/bitstream/10722/155605/1/Content.pdf
Authors managed to light 28W HE tube directly from 220V line without using an autotransformer, by a series L-C magnetic ballast. This idea was discussed recently on the L-G in the context of a crappy cheap shoplight which was able to run 103V F40T12 tubes directly from 120V American mains. Current crest factor, unsurprisingly for a capacitive ballast, is high, though, so bye-bye tube lifetime. Chinese authors do not mention this, but they have oscillograms in the paper.
