Author Topic: Green Beans Arcing in Microwave  (Read 9415 times)
Green Beans Arcing in Microwave « on: April 30, 2025, 10:06:38 PM » Author: Cole D.
I’ve noticed for years now, that green beans sometimes arc when microwaving them.
Tonight I was heating up my dinner plate, and had green beans on it. I covered with a paper towel to prevent spattering. While I was microwaving, had it set for 30 seconds, my mom called me over to look at something on TV.
When I turned around after about 5 seconds to see how many seconds left, I saw that the paper towel had caught on fire, probably due to the green bean arcing! I stopped the microwave, but the fire kept going and set the rim of plate on fire as well, I just left the door shut until the flames went out.
It smelled terrible and wasted whole plate of food, had to throw away, food was covered in ashes. :( So I’d advise to be careful about microwaving green beans, because they do frequently arc. But this is the first time I’ve had it actually catch fire.
Re: Green Beans Arcing in Microwave « Reply #1 on: April 30, 2025, 10:24:48 PM » Author: dor123
Never put a paper towel in the microwave. It can catch fire, because of the heat of the food.
Re: Green Beans Arcing in Microwave « Reply #2 on: April 30, 2025, 10:55:16 PM » Author: Cole D.
I’ve always done it, to keep food from spattering. Never had an issue.
Re: Green Beans Arcing in Microwave « Reply #3 on: April 30, 2025, 11:08:46 PM » Author: dor123
Green beans don't causes arcing. I would put a plastic cover above the rotating plate.
Laurens
Re: Green Beans Arcing in Microwave « Reply #4 on: May 01, 2025, 02:16:59 AM » Author: Laurens
Paper should not catch fire in the microwave, it does not absorb enough radio waves for that. It can be set on fire if the plate it is on contains metallized paint, or if the food is arcing for some reason.
The food should NEVER get hot enough to get paper to catch fire. You need well over 200 degrees C for that. Food which contains water cannot get over 100 degrees, unless you nuke it for so long the water boils away (but then you're in different problems).
Regardless i'd use microwave foil, a microwave safe plate, or indeed some plastic lid.
Finally, things CAN arc in a microwave.
I've had it happen with something. I forgot what it was. But it is well known that two grapes that touch or almost touch each other work as a good enough antenna to receive a significant amount of power and start arcing at the 'antenna feedpoint' (where the two grapes touch).
Re: Green Beans Arcing in Microwave « Reply #5 on: May 01, 2025, 04:22:46 AM » Author: dor123
I thought only metal can create arcs in the microwave.
Laurens
Re: Green Beans Arcing in Microwave « Reply #6 on: May 01, 2025, 07:09:30 AM » Author: Laurens
Anything conductive (read: containing water and minerals) and of the right size and shape can work as an antenna. Because the field strenght is super high, even imperfect conductors can absorb enough radio waves to cause arcing.
Re: Green Beans Arcing in Microwave « Reply #7 on: May 06, 2025, 12:41:23 AM » Author: Medved
Even more impressive is arcing from a flame (candle,...). But that is usually a death sentence for the microwave (or at least its ability to be usable with food again)...
rapidstart_12
@rs12official
Re: Green Beans Arcing in Microwave « Reply #8 on: July 01, 2025, 09:07:42 PM » Author: rapidstart_12
I have had a few frozen food items that tell you specifically to put a paper towel over the food.
Re: Green Beans Arcing in Microwave « Reply #9 on: July 01, 2025, 11:06:05 PM » Author: Medved
"Cover this by paper" and similar dangerous nonsense is very often present on many food labels. The thing is, the food producers do not bear the responsibility if something bad happens because of those advices, unless it directly makes the food dangerous. Here the paper towel by itself does not damage the food, the fact is sets the microwave on fire is not the food makers business, it is not related to the food.
I would really not put any paper into the microwave, unless it is (the paper thing) dspecially intended for use in microwaves. The thing is, the microwave oven is meant to heat especially water, but heats up whatever has ane losses on that 2.45GHz, mainly if the things are conductive or contain conductive materials.
With paper you generally do not know what is in it (beside not being direct health hazard when used to pack/cover food), if e.g. it contains some carbonized fibers (created by e.g. worn out wood milling machinery) or so. Plus any splashes on it may reach temperatures to carbonize and in the carbon form overheat and ignite the paper.
A single speck and because the paper is so easy to ignite, you have a fire.
To protect the mica antenna cover window from splashes (those tend to carbonize on it and then overheat, melt it and cause arcing there, usually killing the magnetron), better to use thode polypropylene cover bowls.
Actually I wouldn't be surprised if the fire started not by the paper igniting by itself, but actually the contaminated mica cover started arcing and setting the paper on fire...
