Author Topic: Aviation T5 Sockets  (Read 4308 times)
Multisubject
Aviation T5 Sockets « on: May 01, 2025, 12:18:54 PM » Author: Multisubject
Some T5 fluorescent tubes designed for aircraft have different connectors at the end of the tube. The bases look pretty much the same as an Intermediate Edison base but not threaded, just smooth metal tubing.
Does anybody know what these are called? Where do you find them?
 :a_fluor:
Re: Aviation T5 Sockets « Reply #1 on: May 02, 2025, 07:11:12 AM » Author: RRK
For Soviet/Russian aviation T5 fluorescent lamps like ЛБ8-2, these are called S15s/12. Historical Soviet name probably 1Ц15-1
Looks close to B15, but without bayonet pins, and with a pressed groove near vitrite insulator.
Re: Aviation T5 Sockets « Reply #2 on: May 02, 2025, 07:15:44 AM » Author: RRK
James lists the bases of American lamp as S14s http://lamptech.co.uk/Spec%20Sheets/D%20FL%20UV%20GE%20F4O5-Blue.htm
My Soviet ЛБ4-2 lamps have bases that measures exactly 15mm, though.
Multisubject
Re: Aviation T5 Sockets « Reply #3 on: May 02, 2025, 10:59:11 AM » Author: Multisubject
So they are called S14s sockets? Where can you get them (if anywhere)?
Re: Aviation T5 Sockets « Reply #4 on: May 02, 2025, 01:52:28 PM » Author: RRK
Or S15s. Google or whatever is your friend, as usual.
I just soldered the wires to the tube directly.
Multisubject
Re: Aviation T5 Sockets « Reply #5 on: May 02, 2025, 05:46:39 PM » Author: Multisubject
All I am getting is turn signal sockets, and none of them have the plunger-action needed to install a fluorescent tube, so I suppose I am out of luck
lightsofpahrump
Re: Aviation T5 Sockets « Reply #6 on: May 07, 2025, 12:13:25 PM » Author: lightsofpahrump
You can use a fuse holder of the right size and a bent bit of metal, if you are willing to live a little dangerously.
I like math, lighting, computers and electronics(but I detest pointless ruinage of nice old stuff). LEDs should be better thought out. they are actually quite good if they are good quality. They should be built to a long life not to a cheap price!
Freedom's not slavery, communism is!
Multisubject
Re: Aviation T5 Sockets « Reply #7 on: May 07, 2025, 01:06:56 PM » Author: Multisubject
At that point I would probably just make the whole thing with some bent strips of brass. If I need a socket I will probably do this. I might 3D print covers for the ends if necessary.
