Author Topic: Strange color from EOL fluorescent  (Read 4771 times)
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Strange color from EOL fluorescent « on: May 21, 2025, 07:35:14 AM » Author: LightsAreBright27
I had a cool daylight 14w T5 that was eol, so I roasted it on an instant start ballast. But after the eol show the tube dimmed and glowed blue. The blue light was similar to BL colour. It only lights up with a tesla coil now. Compared to a normal 20w tube in picture.
245v 50Hz
Re: Strange color from EOL fluorescent « Reply #1 on: May 21, 2025, 08:39:04 AM » Author: dor123
Lamp probably got contaminated.
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Strange color from EOL fluorescent « Reply #2 on: May 21, 2025, 09:23:28 AM » Author: LightsAreBright27
Here's a similar one. A 36w pll lamp. This one atleast glows on the ballast. But one electrode glows orange.
245v 50Hz
Re: Strange color from EOL fluorescent « Reply #3 on: May 22, 2025, 01:44:31 AM » Author: RRK
You may set off that 'harakiri' hydrogen releasing EOL protection device in 14W tube!
LightsAreBright27
Cheap LED Assassin
@LightsAreBright27
Re: Strange color from EOL fluorescent « Reply #4 on: May 23, 2025, 04:32:55 AM » Author: LightsAreBright27
The 14w tube ran with a bright orange cathode. Then half of the tube became orange, and then turned off. There was a slight glow on the other electrode, but the lamp couldn't turn on. I got it to glow blue from a tesla coil.
245v 50Hz
Re: Strange color from EOL fluorescent « Reply #5 on: May 23, 2025, 05:43:25 AM » Author: dor123
The cathode may be broken and an arc formed between the two ends of the filament, and burning it through the glass stem and turning orange, finally causing vacuum loss.
Re: Strange color from EOL fluorescent « Reply #6 on: May 23, 2025, 04:58:16 PM » Author: RRK
Easy to tell which scenario happened in this lamp. If there is a crack developed, internal volume will rather quickly equalize to the atmosphere, and lamp will refuse to light up at any E-field strength. Short of direct sparks in the air at 1bar. If harakiri device was triggered, internal volume is filled with hydrogen, but still vacuum tight, so the lamp will continue to light up blue-purple on Tesla coil infinitely.
