Author Topic: Why CMH lamps have wider thallium line compared to QMH lamps  (Read 4401 times)
Why CMH lamps have wider thallium line compared to QMH lamps « on: May 31, 2025, 11:32:49 AM » Author: dor123
I've noticed that CMH lamps have wider thallium line than QMH lamps except green MH lamps.
You can compared these two spectra of CMH and QMH lamps:
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-248652
https://www.lighting-gallery.net/gallery/displayimage.php?pos=-251779
Why this is happens?
Re: Why CMH lamps have wider thallium line compared to QMH lamps « Reply #1 on: May 31, 2025, 12:15:38 PM » Author: James
Because the thallium vapour pressure is higher, as are all other elements.  Ceramic metal halide lamps typically have a cold spot temperature about 200K hotter than quartz equivalents.
Re: Why CMH lamps have wider thallium line compared to QMH lamps « Reply #2 on: May 31, 2025, 12:39:34 PM » Author: dor123
So how green MH lamp have the same thallium line width as CMH lamps?
Re: Why CMH lamps have wider thallium line compared to QMH lamps « Reply #3 on: May 31, 2025, 05:30:41 PM » Author: RRK
Are you sure you are equipped to measure this reliably and not getting the camera saturated instead?
Re: Why CMH lamps have wider thallium line compared to QMH lamps « Reply #4 on: May 31, 2025, 09:14:10 PM » Author: dor123
Yes. I know how to get a good spectra with my camera and my DVD-R.
Re: Why CMH lamps have wider thallium line compared to QMH lamps « Reply #5 on: June 09, 2025, 07:31:37 AM » Author: dor123
And if there is no advantage of wider thallium green line in CMH lamps, the thallium dose can be reduced.
