Author Topic: Non passive metal halide lamp failure sets low bay fixture on fire  (Read 18465 times)
UChBXesrxSalDTp79uMtfDvA
Non passive metal halide lamp failure sets low bay fixture on fire « on: October 27, 2025, 06:58:26 PM » Author: WorldwideHIDCollectorUSA
Anyone seen anything like this before?
https://youtube.com/shorts/xKejh6rIAqY?si=T4bclOKIAZ3UF5J9
Multisubject
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #1 on: October 27, 2025, 07:24:00 PM » Author: Multisubject
Wow, that is impressive. I don't think that fire was likely to spread (unless the flaming plastic was dripping onto something flammable), but it was very close to a sprinkler which could heat up and go off. Not a fun situation, that could have been a lot worse.
Lightingeye60
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #2 on: October 25, 2026, 05:22:54 PM » Author: Lightingeye60
This is the reason why plastic refractors shouldn’t be used on MH fixtures. All MH fixtures should have a glass refractor. Assuming these were 250 or 400 watts.
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #3 on: October 25, 2026, 05:23:49 PM » Author: WorldwideHIDCollectorUSA
Otherwise, these fixtures should use open rated lamps with arc tube shrouds.
Lightingeye60
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #4 on: October 25, 2026, 05:25:43 PM » Author: Lightingeye60
Yes, and I also think all metal halide fixtures should have a GLASS refractor. Using a plastic refractor on a metal halide fixture is stupid to begin with. Plastic refractors should only be used in MV or HPS fixtures or lower wattage.
But yes, using a protected lamp might’ve prevented this.
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #5 on: October 26, 2026, 04:06:53 AM » Author: dor123
I thought all low bay fixtures are made from glass rather than plastic.
SoxFtw
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #6 on: October 26, 2026, 10:50:34 AM » Author: SoxFtw
Yes, and specially so in a lamp burning BASE UP. If I had a say in the matter, it would be glass/porcelain for any lamp >100W. Metal halides have the greatest risk of non-passive failure so using flammable palstic right next to it doesn't seem too bright.
Survivor of photokeratitis :(
👉KeepAndroidOpen.org👈
Laurens
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #7 on: October 26, 2026, 12:06:10 PM » Author: Laurens
How coincidental! I just DM'd a forums member who i hold in high esteem about how to deal with (small) exploding MH lamps (James), that i want to use inside my house. I have a few specific ones i want to use, instead of the ones that are designed to fail safe in open luminaires, because of their technical peculiarities not found in the fail safe ones.
For protection 4mm tempered glass panes he recommended, or quarz tube but that is likely very expensive. My goal is to just be able to hang it from the ceiling. A glass box with overlapping panes will be suitable for that. Only issue is that tempered glass is even harder to cut than normal stuff...
E: with regards to that video - it is why in many countries polystyrene thermal isolation is not allowed for overhead use (like roof isolation). Even if it is self extinguishing, it oozes hot, possibly still burning sticky messes of plastic that are incompatible with human skin.
« Last Edit: October 26, 2026, 12:29:22 PM by Laurens » Logged
LightbulbHPS_CFL
LightbulbHPS_CFL LightbulbHPS_CFL
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #8 on: November 01, 2026, 03:18:23 PM » Author: LightbulbHPS_CFL
"F**K!" Why are you standing directly under it? ???
:eoled: This is why we don't use crappy LED replacements.
See my site here
Lightingeye60
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #9 on: November 08, 2026, 11:25:39 AM » Author: Lightingeye60
I don’t know why they were standing under it.
Stupid design anyways. A metal halide fixture shouldn’t even have a plastic refractor.
SoxFtw
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #10 on: November 08, 2026, 11:47:00 AM » Author: SoxFtw
Quote from: Lightingeye60 (previous reply)
Or for that matter, any HID or even high-wattage incandescent fixture.
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #11 on: November 21, 2026, 10:48:17 AM » Author: wide-lite 1000
 @dor123 : Most low bays I've seen have plastic refractors .
 For everyone else : This usually is only an issue if the fixture isn't properly maintained and allowed to run a lamp WAY past rated life .  The company I work for used open 400w MH highbays with standard lamps for over 20 yrs. ! In that time , only 1 out of over a 100 fixtures had a non-passive failure !
Re: Non passive metal halide lamp failure sets low bay fixture on fire « Reply #12 on: November 21, 2026, 11:10:42 AM » Author: joseph_125
Yeah I think relamping at the end of rated life and also shutting them off for to let them fully cool down every two weeks also reduces the risk. Open rated lamps were also available if explosions was a concern as well.
What does surprise me is that the plastic used on the refractor did not have a flame retardant on it, you can get plastics with additives that meet UL94-V0 requirements and should self extinguish within 10 seconds without dripping flaming material below.
