Author Topic: Impact of a cycling lamp  (Read 6196 times)
stillaintjeff24
Impact of a cycling lamp « on: November 30, 2025, 12:54:37 AM » Author: stillaintjeff24
How bad is a cycling lamp for a fixture? I have a Hps Wallpak, and the lamp cycles. I think it’s cool looking, but I know it is hard on the components. How bad is it to have it running for maybe 2 or 3 hours?
Re: Impact of a cycling lamp « Reply #1 on: November 30, 2025, 12:56:44 AM » Author: WorldwideHIDCollectorUSA
As far as I know, a cycling lamp causes wear on the ignitor and possibly the ballast insulation if left neglected for too long as the ignitor would keep attempting to restrike the lamp over and over again when the lamp goes out. Ideally, you would want to replace your lamp as soon as possible.
Re: Impact of a cycling lamp « Reply #2 on: November 30, 2025, 02:54:00 AM » Author: Ash
This is indeed the general answer. A more specific answer depends on additional considerations :
Ballast insulation quality varies. Some ballasts don't mind it too much even for years, while others may be damaged
If the ballast is exposed to moisture, its insulation may be bad enough to the point where it barely withstands even normal lamp starting or plain line voltage. In this case the cycling lamp may just what pushes it over the edge
A ballast independent (superimposed) ignitor does not expose the ballast to ignition voltage, in this case the ballast only have to withstand Voc, which any intact ballast will withstand indefinitely
Ignitor quality varies. I have seen an install with 5 floodlights, of which 3 were powered full nights for 12 years with no lamps installed, continuously ticking all night long, and were still intact. (Eltam K75 ballasts and ES50 ignitors)
The worst ignitors i have seen have underrated components which can't survive the "lamp open circuit" condition for too long. In one such ignitor the charging resistor melted right out of the side of the ignitor through the plastic. This is not result of the ignition voltage, but just of it getting powered at Voc (charging the ignitor from the ballast output) for too long
Some ignitors are "smart" types that stop attempting ignition or reduce it to quick attempts with long delay between them if they figure out that the lamp is bad
The luminaire wiring and especially remote ballast wiring is also susceptible to damage from ignition voltage if there is any initial small damage to the insulation
Re: Impact of a cycling lamp « Reply #3 on: November 30, 2025, 04:20:00 AM » Author: dor123
There are two types of anti-cycle ignitors:
1. One that gives up ignition attempts after few number of cycles.
2. One that monitors the lamp conditions and fires to stabilize a lamp that about to extinguish, and gives up ignition attempts after the lamp extinguished.
Re: Impact of a cycling lamp « Reply #4 on: November 30, 2025, 04:34:32 AM » Author: RRK
I know once there was a fire caused by neglecting to use a regular not-HV rated cable from ballast box to luminaire in the case of non-igniting MH lamp! So far, so good, ask me how I got four combos of nice NOS Tridonic 150W chokes with nice NOS Tridonic igintors for VERY cheap haha!
Re: Impact of a cycling lamp « Reply #5 on: November 30, 2025, 04:37:55 AM » Author: dor123
@RRK: Are the Tridonic ignitors you got, anti-cycle or regular?
Re: Impact of a cycling lamp « Reply #6 on: November 30, 2025, 04:48:21 AM » Author: RRK
ZRM 4.5-ES/C marketed as ignition cut-off, not sure if smart enough to prevent cycling, too.
Ignitor being TOO smart is the source of its problems in practice unfortunately...
Re: Impact of a cycling lamp « Reply #7 on: November 30, 2025, 05:00:40 AM » Author: RRK
Though, looking more carefully, it seems that ignitors should be ES/CT version to have timed cutoff.
Re: Impact of a cycling lamp « Reply #8 on: November 30, 2025, 05:05:55 AM » Author: RRK
Inexpensive American luminaire is probably using a tap on the ballast choke to generate HPS HV ignition pulses. So yes, cycling HPS is stressing choke insulation repeatedly. How bad is this in practice, hard to tell, as HPS ignition voltage is typically low, less than 2kV.
stillaintjeff24
Re: Impact of a cycling lamp « Reply #9 on: November 30, 2025, 05:30:07 AM » Author: stillaintjeff24
It seems to have the same ignition correct as any other American ballast would.
Re: Impact of a cycling lamp « Reply #10 on: November 30, 2025, 06:07:42 AM » Author: RRK
If you have a wire going from an ignitor to a special tap on ballast choke or transformer, then yes, you have semiparallel ignitor circuit that uses ballast windings to get high ignition voltage.
stillaintjeff24
Re: Impact of a cycling lamp « Reply #11 on: November 30, 2025, 06:10:56 AM » Author: stillaintjeff24
Why though? Even with a proper ignitor in place they still need to cheat with the ballast windings?
Re: Impact of a cycling lamp « Reply #12 on: November 30, 2025, 06:18:56 AM » Author: RRK
As it was said before already, superimposed ignitor works completely independent to ballast circuitry and even can be housed remotely. AFAIK, superimposed ignitors are not popular in US for some reason and probably not practical with low voltage HPS lamps. To clarify, there is three classes of HID ignitors, parallel, so called semi-parallel, and superimposed. Parallel ignitor just runs just parallel to the lamp. It uses its own HV generator circuit but still subjects ballast output to HV pulses. Semi-parallel uses ballast winding as high-voltage autotransformer. Superimposed is completely independent and isolates ballast from lamp ignition.
« Last Edit: November 30, 2025, 06:25:28 AM by RRK » Logged
stillaintjeff24
Re: Impact of a cycling lamp « Reply #13 on: November 30, 2025, 06:20:44 AM » Author: stillaintjeff24
Yeah, ignitor circuits are confusing to me. I get it, thanks.
Re: Impact of a cycling lamp « Reply #14 on: November 30, 2025, 06:32:28 AM » Author: dor123
The American semi-parallel ignitors are of different topology than the European semi-parallel ignitors.
Also @RRK: Only parallel and semi-parallel ignitors can use for remote ignition. Superimposed ignitors must be close to the lamp.
