Author Topic: Why It Was a Nightmare to Create the White LED  (Read 31414 times)
Omnilight37
Keep Shining
Why It Was a Nightmare to Create the White LED « on: June 21, 2026, 03:22:15 PM » Author: Omnilight37
 :eoled:  We often take LEDs for granted, but they really are the backbone of modern life. They power everything from late-night highway commutes and grocery store aisles to massive sports stadiums, smartphones, and even the screen you are reading this on right now. Simply put, they are vital to the global economy. However, very few people actually stop and ask themselves "How did this magnificent technology arise?", but not us.
To understand how this revolution happened, we have to look back at the late 20th century, when the tech world was stuck in a frustrating color stalemate. By the 1970s, electrical engineers had easily mastered red and green LEDs. They lit up digital alarm clocks and VCRs across the globe, but a true holy grail remained elusive: the blue LED. Without blue, scientists could not mix the three primary colors to create energy-efficient white light—the kind needed to replace the world's power-hungry lightbulbs and illuminate crisp flat-screen displays. Global tech giants like IBM, General Electric, and Bell Labs poured millions into solving the blue dilemma, eventually giving up after concluding it was functionally impossible. The issue boiled down to chemistry. The most promising candidate material was gallium nitride (GaN), a crystal notoriously stubborn to grow and even harder to alter into a conducting semiconductor.
  In 1989 in Tokushima Japan, Shuji Nakamura was an unassuming, under-credentialed engineer working for Nichia Corporation, a tiny chemical company located in rural Tokushima, Japan. Operating in near-total geographic and professional isolation, Nakamura defied corporate skepticism and the entire global scientific consensus by choosing to tackle (GaN). Because Nichia had virtually no budget, he famously welded and built his own chemical vapor deposition equipment from scratch.  However, science is rarely a truly solo endeavor; Nakamura’s breakthroughs were destined to collide with the work of other brilliant minds. Just a few hours away at Nagoya University, Japanese professors Isamu Akasaki and Hiroshi Amano were also obsessively chasing GaN. In the late 1980s, Akasaki and Amano achieved a critical milestone: they used an electron microscope beam to zap magnesium-doped GaN, creating the world's first "p-type" semiconductor layer necessary to pass an electrical current.
Nakamura studied their academic papers, but he realized their method was far too slow for mass production. Innovating rapidly, Nakamura discovered that simply thermal annealing (heating) the crystal at a specific temperature naturally broke apart the microscopic hydrogen bonds that were choking the electricity. He then engineered a brilliant "Two-Flow" gas delivery system that allowed him to grow flawless, ultra-thin layers of indium gallium nitride (InGaN) to trap electrons and maximize brightness. By 1993, Nakamura had done what the world's greatest corporate laboratories couldn't: he produced a commercially viable, blindingly bright blue LED.
The global impact was instantaneous, though the human story took a dramatic turn. While Nichia generated billions from the invention, Nakamura was initially compensated with a measly bonus of just $200. Insulted, he eventually left Japan for a professorship at the University of California, Santa Barbara, and shook the tech industry by successfully suing his former employer for millions in royalties. The ultimate vindication arrived in 2014, when Nakamura, Akasaki, and Amano jointly won the Nobel Prize in Physics. The Nobel committee perfectly summarized the weight of their intersecting work, noting that if the 20th century was lit by incandescent bulbs, the 21st century would be lit by LED lamps—all thanks to a relentless engineer who refused to believe that blue was impossible.
« Last Edit: August 02, 2026, 07:25:13 PM by Omnilight37 » Logged
*Getting Brighter by the Day!*
I'm an avid lighting enthusiast who works with and studies ballasts, ignitors and lighting optics while identifying various models and manufacturers of electric lighting. I am actively studying particle physics and seek to understand the mechanics of a photon.
Baked bagel 11
Tom
UCO6cAQm377MpL943-mH_DHw
Re: Why It Was a Nightmare to Create the White LED « Reply #1 on: June 21, 2026, 05:37:21 PM » Author: Baked bagel 11
Awesome write-up, a very fascinating read.
Omnilight37
Keep Shining
Re: Why It Was a Nightmare to Create the White LED « Reply #2 on: June 21, 2026, 10:15:59 PM » Author: Omnilight37
Thank you! I appreciate it.
Re: Why It Was a Nightmare to Create the White LED « Reply #3 on: June 21, 2026, 11:54:50 PM » Author: RRK
Written with a touch of sensationalism, sure. It was not a nightmare, but Nakamura was the first to devise a method to create GaN clean enough to work properly in blue LEDs.
Re: Why It Was a Nightmare to Create the White LED « Reply #4 on: June 22, 2026, 01:58:27 AM » Author: Medved
Well it is not only for LEDs, but for any modern power electronics, it is the enabler why it is possible to create socket size power converter handling 100W while not ending up in smoke: The low loss switching elements required to achieve that are built using GaN as the principal semiconductor and that became possible with the same invention.
But that is also tightly tied to the LEDs: The GaN becomes the choice material for these power stages is enabled by the GaN becoming cost competitive just because the main driver force for its fabrication is the LED business, as it demands so much of it it allows the economy of scale to reduce the GaN base semiconductor material manufacturing cost even when the process itself is extremely demanding and complex (compare to e.g. the traditional silicon). There are other high band gap "competitors" for the power components, but because of the way smaller scale they are way more expensive.
Re: Why It Was a Nightmare to Create the White LED « Reply #5 on: June 22, 2026, 11:32:32 AM » Author: dor123
But Nakamura isn't the inventor of the blue LED. Herbert Paul Marushka invented a GaN blue LED in 1972, and Cree developed a SiC blue LED at 1989. Nakamura only perfected the blue LED.
Omnilight37
Keep Shining
Re: Why It Was a Nightmare to Create the White LED « Reply #6 on: June 22, 2026, 12:16:13 PM » Author: Omnilight37
Correct, Nakamura didn't create the blue LED. That was done before his breakthrough in 1972 by American scientist Herbert Paul Maruska. However, Nakamura successfully commercialized it and made it economically viable.
« Last Edit: June 22, 2026, 12:34:12 PM by Omnilight37 » Logged
Re: Why It Was a Nightmare to Create the White LED « Reply #7 on: June 22, 2026, 05:35:23 PM » Author: James
A great account and nicely prepared, but I would also say Nakamura was not the creator of either the blue or the white LEDs, or even the first to commercialise those.  All four of Telefunken, Siemens, Hewlett-Packard and CREE did that very successfully and many years beforehand.  Blue LEDs were even mass produced in huge volumes for certain applications like the high beam indicator of some car dashboards in the 1980s - but they were quite dim and not very efficient.  What Nakamura really achieved was to create an important advance in both efficacy and power density - so his invention created blue LEDs that were somewhat brighter than their predecessors, and cheaper in terms of cost per lumen (but at first not cheaper in terms of unit price).  The advance was significant, but perhaps also not so much as we consider now.  The real advances in blue and white LED performance came after the first steps had been taken by Nakamura, and by many other companies and research institutes.
Nakamura was (and is) described as a brilliant engineer who is also something of a showman, he is a master at drawing an audience and blowing his own trumpet.  He achieved this with such strength and choice of words that it swayed the opinion of peers to consider that he really was the first to create blue and white LEDs, and to virtually eradicate the memory of all predecessors.  This is very often the case with great inventions.  For instance Swan and Edison were by far not the original inventors of the incandescent lamp - at least fifty others achieved that success in the decades before them.  They were simply the ones who were rich enough and lucky enough to raise performance and reduce system costs to such a degree of simplicity that it could be better afforded by the masses.  As such their names were stuck in history.  Any account that considers them as inventor of the incandescent lamp is seriously flawed.  Similarly it was not GE that invented the fluorescent, mercury, high pressure sodium or metal halide lamps, as that company liked to claim for many decades.  They were just one of the more successful competitors at marketing particular variants that enjoyed commercial strength, based on designs that had already been established by others.  But still, this is a nice article that will hopefully inspire many more to research the fascinating histories of lighting developments!
Omnilight37
Keep Shining
Re: Why It Was a Nightmare to Create the White LED « Reply #8 on: June 22, 2026, 09:38:54 PM » Author: Omnilight37
Thank you for your response. The blue led did not exist before 1993. The invention of the blue LED was the prerequisite for the invention of the white LED. The blue LED was invented and made commercially viable by Shuji Nakamura in 1993 whereas the white LED was invented years later in 1996 at the Japanese company Nichia by Shuji Nakamura. He had to work in the dark and keep his laboratory secret as his managers prohibited from trying to invent the white LED as they thought it wouldn't be possible to make.
Re: Why It Was a Nightmare to Create the White LED « Reply #9 on: June 23, 2026, 01:47:39 AM » Author: Medved
The blue LEDs technically did exist, but fact is they were practically unusable, even as indicators. There even were "white" full spectrum LEDs (the junction itself created the full spectrum, not any phosphor; the band gap has gradient over the junction area and the junction itself needed to have rather high ballasting resistance to keep the current density across all regions uniform, heavily degrading the efficiency), with even worse efficiency, so also more a gimmicks than anything practical.
And it was the invention of the GaN based semiconductor manufacturing what finally enabled the commercially viable blue LEDs (and with a phosphor many other colors).
Omnilight37
Keep Shining
Re: Why It Was a Nightmare to Create the White LED « Reply #10 on: June 23, 2026, 12:49:04 PM » Author: Omnilight37
  :eoled: I agree, but at that time they weren't considered revolutionary technology. They were invented by RCA (Radio Corporation of America) in 1972 by Herbert Maruska and at the time were just considered a scientific novelty. They were never sold because they were too weak and insufficient. It wasn't until 1993 when Nakamura revolutionized the technology that they became economically viable and a critical stepping stone for the white LED.
Omnilight37
Keep Shining
Re: Why It Was a Nightmare to Create the White LED « Reply #11 on: June 24, 2026, 07:54:59 PM » Author: Omnilight37
Thanks for your message. Shuji Nakamura created the Indium Gallium Nitride (InGaN) crystal by custom-building his own Metal Organic Chemical Vapor Deposition (MOCVD) reactor. By forcing Indium and Gallium to mix at high temperatures, he overcame the assumption that the two materials were incompatible, successfully growing a high-quality InGaN sandwich structure necessary to emit bright blue light.
lightsofpahrump
Re: Why It Was a Nightmare to Create the White LED « Reply #12 on: July 11, 2026, 11:37:55 PM » Author: lightsofpahrump
Quote
Some people still got CCFL backlit monitors or CRT screens!
Omnilight37
Keep Shining
Re: Why It Was a Nightmare to Create the White LED « Reply #13 on: July 12, 2026, 02:19:42 PM » Author: Omnilight37
  I sure do miss the old CCFL pixels of the 90s! Can you imagine what a computer powered by HPS pixels what be like?   :laugh:
Re: Why It Was a Nightmare to Create the White LED « Reply #14 on: July 12, 2026, 02:37:47 PM » Author: RRK
My colleague still has a working laptop using orange neon plasma display panel!
