Author Topic: Which metal halide bulb do you prefer? Clear or coated?  (Read 3771 times)
Lightingeye60
Which metal halide bulb do you prefer? Clear or coated? « on: August 19, 2026, 06:05:17 AM » Author: Lightingeye60
What metal halide bulbs do you prefer? Clear or coated?
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #1 on: August 19, 2026, 07:14:04 AM » Author: dor123
I prefers clear MH lamps where you can see the arctube and the arc inside clearly.
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #2 on: August 19, 2026, 10:26:10 AM » Author: sol
Depends on the application. In my living room, I have a coated lamp because it reduces the harshness and glare. However, if the lamp is used in glassware (such as Holophane) and not too close to the eyes, then I prefer clear because of how the light plays in the glass. Also, if I am experimenting with DIY fixtures using G8.5 or G12 lamps, I have no choice but to go with clear.
Otherwise, I'm with dor on this one, I prefer clear lamps.
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #3 on: August 19, 2026, 06:54:29 PM » Author: wide-lite 1000
 I agree . I also have a coated lamp in my RAB Area Light JR . I initially had a clear in it but the pattern had WAY too many "hot spots" for my liking . I changed to the coated version and the area is nice and evenly lit now with no more "hot spots" I use clear when optical control is required (my Wide-lite) or something with a nicely patterned refractor .
BT25
Vintage HID Collector
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #4 on: August 19, 2026, 07:05:56 PM » Author: BT25
Prefer clear...especially the Philips Allstart series.
HID - Lighting with personality.
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #5 on: August 19, 2026, 09:35:01 PM » Author: icefoglights
Unless I have a reason to go with diffused, I generally prefer clear.  Works out well since they're by far the most common.
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #6 on: August 20, 2026, 03:14:13 AM » Author: HomeBrewLamps
I prefer these metal halide bulbs
https://www.lighting-gallery.net/gallery/displayimage.php?album=4644&pos=10&pid=165845
UChBXesrxSalDTp79uMtfDvA
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #7 on: August 20, 2026, 03:49:54 AM » Author: WorldwideHIDCollectorUSA
For me, I prefer retrofit quartz and ceramic metal halide retrofit lamps for mercury vapor fixtures sold in Japan the best.
Econolite03
Matthew E.
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #8 on: August 20, 2026, 06:38:33 AM » Author: Econolite03
Always clear, never really been a fan of coated MH especially for the higher wattages.
 :bumh:
All Hail the GE M-400
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #9 on: August 20, 2026, 06:39:50 AM » Author: dor123
Coated MH lamps are suitable for high bay and low bay fixtures, where they burns vertical.
Lightingeye60
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #10 on: August 20, 2026, 09:33:31 AM » Author: Lightingeye60
 :bumh:
I actually prefer coated MH. Though in fixtures with certain optics, clear lamps may be a better fit. In general I prefer coated HID lamps (whether metal halide, mercury vapor, or even HPS).
« Last Edit: August 20, 2026, 09:39:44 AM by Lightingeye60 » Logged
Lightingeye60
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #11 on: August 20, 2026, 09:51:48 AM » Author: Lightingeye60
Do you prefer clear MH or coated MH overall?
BuzzyBallast
Electrician with a heart like a raccoon
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #12 on: September 15, 2026, 11:11:31 PM » Author: BuzzyBallast
I prefer clear especially in the lower wattages they have a certain sparkle about them.
suzukir122
suzukir123
Re: Which metal halide bulb do you prefer? Clear or coated? « Reply #13 on: September 18, 2026, 12:03:19 AM » Author: suzukir122
I prefer clear, especially for places like my garage. All of my Metal Halides in my garage are using clear 50w lamps in those wallpacks. However, in situations
where there may be hotspots, I prefer coated. Case in point, the Ceramic Metal Halide PAR38's that I'm using in my bathroom. All of those are clear, and their
bright beams are lighting only one portion of the ceiling, not all around... so the rest of the ceiling in the bathroom isn't getting much light. Still looks
nice, but it would look much nicer if the light spread apart more evenly. This would be the case if they were coated, and I may have a plan for that in the
near future.
Overall though, I definitely prefer clear Metal Halide. Coated Metal Halides lamps are awesome too though.
Interests:
