Author Topic: Have you’ve seen metal halide GE TC-100 post tops?  (Read 2918 times)
Goodlighting2000
Have you’ve seen metal halide GE TC-100 post tops? « on: September 13, 2026, 08:31:04 AM » Author: Goodlighting2000
Have you’ve ever seen a GE TC-100 fixture in MH?
Or, have you’ve only seen them in HPS or only seen them in HPS and MV? I’ve only seen them in 100W HPS. Were metal halide versions common?
Did GE make PSMH versions of the TC-100?
Re: Have you’ve seen metal halide GE TC-100 post tops? « Reply #1 on: September 13, 2026, 06:53:56 PM » Author: wide-lite 1000
Personally , I've only seen them in MV or HPS . I found a 1977 GE catalog on Scribd and it only lists HPS & MV .
Lightingeye60
Re: Have you’ve seen metal halide GE TC-100 post tops? « Reply #2 on: September 14, 2026, 07:08:55 AM » Author: Lightingeye60
Yes, they did. I found a 2005 catalog, 2000s spec sheets, and they did make one in 175W probe start metal halide. Don’t know if PSMH ones existed or if they were all HPS after probe start metal halide got banned.
The HPS and mercury vapor versions are far more common and I’ve never found an MH one in person. The GE Town & Country is notorious for having the NEMA tags fade to white so you may not be able to tell what light source it is, but if it says “17” it’s most likely mercury, if it says “10”, it’s most likely HPS, but it can be mercury. Any other tag (5, 7, and 15), if that’s in the fixture, then it’s almost certainly HPS.
« Last Edit: September 14, 2026, 07:36:07 AM by Lightingeye60 » Logged
