Author Topic: Iwasaki LEDioc retrofit lamps  (Read 10104 times)
RandomCatPerson
WESTINGHOUSE OV-14B
Iwasaki LEDioc retrofit lamps « on: October 08, 2026, 12:07:13 PM » Author: RandomCatPerson
Here is a really cool product from Iwasaki, it is a led bulb that looks about as close to HID as I have seen. It uses the same BT shape glass envelope as their HID lamps but with led diodes inside. I unfortunately have not seen anywhere that these are easily available here in the US. here is a video on this rather new product.
https://www.youtube.com/watch?v=I5ATR4N6i14
Lighting hobbyist since 2018
Multisubject
Re: Iwasaki LEDioc retrofit lamps « Reply #1 on: October 08, 2026, 01:35:19 PM » Author: Multisubject
Wow those look so cool, usually the thing that gives it away for the coated ones is that they are coated all the way down to the base, but these must use literally the same exact envelopes as the HID ones. Never seen BT shape retrofits either, that is just so cool. Very nice find, I also have yet to see them for sale.
Re: Iwasaki LEDioc retrofit lamps « Reply #2 on: October 11, 2026, 12:18:03 AM » Author: wide-lite 1000
 Am I seeing correctly that it needs a driver ?
Re: Iwasaki LEDioc retrofit lamps « Reply #3 on: October 11, 2026, 12:02:00 PM » Author: joseph_125
Very cool, it would be cool if the coated version was like the classic coated MV with the tops ad bottom clear.
External driver is probably more practical for something like this. You don't have to worry about cramming it in the lamp base and I'm assuming this is mostly intended to retrofit HID luminaires, which most of them already have a provision for mounting auxiliary equipment anyway.
Re: Iwasaki LEDioc retrofit lamps « Reply #4 on: October 11, 2026, 05:26:11 PM » Author: wide-lite 1000
 The coated version would be nice in 4,000k .
Re: Iwasaki LEDioc retrofit lamps « Reply #5 on: October 12, 2026, 09:04:13 PM » Author: AngryHorse
The Japanese have nailed it here, with lamp and driver, (like a lamp and ballast)  they're street lighting could go back to proper old school methods 👍, it's just a shame the west will carry on with integrated flat lanterns that have to be changed completely! 😖
lightsofpahrump
Anything electro(mechanical) makes me happy
Re: Iwasaki LEDioc retrofit lamps « Reply #6 on: October 14, 2026, 06:26:53 PM » Author: lightsofpahrump
I think this is a great idea, because it enables manufacturers to reuse fixture tooling, as well as often-excellent non-glare HID optical assemblies.Is it a filament LED?
Re: Iwasaki LEDioc retrofit lamps « Reply #7 on: October 14, 2026, 09:01:37 PM » Author: wide-lite 1000
 Looks to have 24 COB chips . I highly doubt ANY manufacturer has any of the tooling or equipment left to make conventional HID style fixtures anymore .
Baked bagel 11
Tom
UCO6cAQm377MpL943-mH_DHw
Re: Iwasaki LEDioc retrofit lamps « Reply #8 on: October 15, 2026, 05:07:31 PM » Author: Baked bagel 11
There are certainly a few, such as Genlux, in South Africa.
Re: Iwasaki LEDioc retrofit lamps « Reply #9 on: October 16, 2026, 10:40:21 PM » Author: joseph_125
I'd imagine most of the tooling to make HID luminaires have either been modified for a LED only variant or scrapped in most cases. I suppose some luminaire designs such as the Holophane Bantam LED are similar enough to their HID predecessors that there's a lot of common housing parts still in production for the LED variant.
Maxim
Re: Iwasaki LEDioc retrofit lamps « Reply #10 on: November 12, 2026, 10:49:53 AM » Author: Maxim
@Robotjulep knows a ton about these lamps; he was in Japan for a few weeks, returned a few days ago... they are everywhere there.
