Goodlighting2000
| So many people on here used to say and still say that Philips Alto lamps frequently burn out early and some even said they kill ballasts, but is that really true? Are Philips Alto’s really that bad?
Econolite03
Matthew E.
The fluorescent tubes I can confirm sucked… go mercury starved very quickly. I wasn’t alive for the pre-Alto HPS stuff so someone else has to touch on that.
All Hail the GE M-400
Lightingeye60
| The older Alto’s yes, they always went mercury starved (and they performed horribly when turned on and off constantly due to weak cathodes).
The energy saving and U-bend Alto’s especially suck. The Alto II’s didn’t go mercury starved as much but they didn’t perform well under frequent short use.
stillaintjeff24
| I have alto IIs and while one bulb did fail within a few months on a instant start ballast, the others on better ballasts look and perfect.
BT25
Vintage HID Collector
If you like reddish-yellow HPS, then Alto/Eco lamps are for you. 'Pre-enviro' HPS with the dreaded Hg were brighter, whiter and just pleasant to be around, but still not as good as a DX. As to Alto/Eco fluorescents, they've always been 'mercury starved'...they came that way from the factory!!!
Econolite03
Matthew E.
@BT25: I’ve definitely noticed that. My early 1980s HPS lamps definitely have a “champagne” color, whereas the post-2001 lamps are a pronounced orange hue. The tubes… probably.
BT25
@Econolite03 - Its the Hg content in the arc-tube. The thought back in the 90's was to make HPS and fluorescent lamps non toxic so they wouldn't pollute the environment...not a bad idea. But typical of government, they didn't cover all the bases with this requirement. Efficacy fell, along with color rendering to the point they became undesirable and were only used in the end, because that's all that was available...except for DX, which still had the dreaded Hg.
« Last Edit: November 23, 2026, 10:50:53 AM by BT25 »
Goodlighting2000
Do all the Alto’s suffer from mercury loss or just some models. I’ve heard the Polish made Alto’s don’t suffer from that failure often and I’ve heard it’s just the older models.
Maxim
| I would argue that Altos made between 1998 and 2006 are good. I don't like any made between 2007 and the closure of Salina (Alto IIs). Poor performers and usually pretty ugly, faded etches on top of everything else.
As to HPS... yes, pre-Alto HPS was *much* more pleasant to bask under... what is their color rendering rating?
Emersyn
@Maxim The 1998-2006 Altos are definitely great. But my dad has some 2012 Altos that have been in (not heavy) use since 2012 and they're doing well. Their etches are fading now, but when they were new they weren't faded. My 2011 Altos seem to be dosed with okay too.
Lcubed3
MAXIMUM LUMENS!!!
| Alto's are alright. We have a garage full of them, and not one has failed yet. They do not have any warm-up time if you use them frequently enough.
There is a F32T8 Rapid Start fixture with two altos over the freezers. That one is switched much more frequently, and neither tube shows any sign of blackening.
We also have a shop light that is left on 24 hours a day with two older Altos, and it shows no sign of mercury starvation after over a year.
I believe Fiet Electric still gives their tubes a full dose of mercury, but I could be wrong.
Portland General Electric: 120/240VAC @ 60Hz Bringer of Light
Econolite03
Matthew E.
I’ll kinda echo what other’s have stated, is that the post-2006 ones seemed to have been when things went south. I feel it impacts most common varieties, particularly the Alto IIs.
Lightingeye60
| The Alto U-bends are the worst for it, though. Those things always go mercury starved. I swear the U-bend’s fail starved more than they actually burn out. I’ve seen two mercury starved Alto U-bend’s in one fixture.
The linear Alto’s (even the Alto II’s) weren’t as bad. The U.S. made Alto II’s were definitely notorious for failing mercury starved and or/with dim partial discharge. The Polish made ones don’t seem to go starved as often, but I’ve seen them a few times.
Lightingeye60
A lot of the Feit tubes are just rebranded Altos. Some of the faux Westinghouse tubes were as well.
davesfireandsafety
Youtube Channel: DavesSafetyFun
| In my experience, altos are one of the best lamps I use.
Whenever I use a fixture that has rapid start or programmed start, silver cap bulbs such as sylvania or GE are my best bet since they don’t have cathode guards, atleast the newer ones, and putting them on an IS ballast is just an EOL speedrun.
On the other hand, Alto bulbs have cathode guards and last significantly longer when switched on and off on instant start.
Therefore, I use altos on instant start and other bulbs on different starting methods
