Author Topic: LED Christmas lights ARRGH!!!!!  (Read 55878 times)
Re: LED Christmas lights ARRGH!!!!! « Reply #15 on: December 19, 2011, 12:19:49 AM » Author: xmaslightguy
While I deff like the old C9 Christmas lights (they are to me true classic Christmas lights), I don't use the sets I have much anymore because they take too much power...
I've always liked mini lights & thats what i used mostly.
I love LEDs for their intense colors and cool whites, and ofcourse the very minimal power useage is awesome!
This year my outside lights are normal incandescent mini's, and cool-white LEDs ... basically I'm treating them as 2 different colors :) I can change colors/do patterns with my setup LOL when I 'flash all' on the mini's, it dims/flickers everything just a bit, 'flash all' on the LEDs caused no dimming at all.
Inside I've gone almost 100% LED.
I'm not a big fan of "half-wave" sets (even tho most of mine are such) - I can easily see the 60hz flicker
I don't care too much for warm-white, its too ordinary/boring - especially those new LED sets that look just like standard mini's
Re: LED Christmas lights ARRGH!!!!! « Reply #16 on: December 19, 2011, 02:57:27 AM » Author: Ash
Looks like you have WAY thin and long ext ension cable or bad connection somewhere, if the load of few A at most (i guess way less ?) makes so noticable volt drop
SeanB~1
Re: LED Christmas lights ARRGH!!!!! « Reply #17 on: December 19, 2011, 11:22:14 AM » Author: SeanB~1
The usual is a single diode goes open circuit, and none of the others work. Sometimes the open circuit voltage is enough to arc the open circuit die into being a short, or they flicker from thermal stress. Often they just go dim, or change colour.
Re: LED Christmas lights ARRGH!!!!! « Reply #18 on: December 19, 2011, 03:11:07 PM » Author: Ash
I noticed it to be the case in many cheapish LED products (even 1 LED ones which are battery powered), but LED strings seem to hold up ok here
Re: LED Christmas lights ARRGH!!!!! « Reply #19 on: December 19, 2011, 07:33:24 PM » Author: xmaslightguy
Quote from: Ash
Quote from: xmaslightguy
Nope, the cords & such are fine (I even checked amps to make sure nothing is overloaded)..
I by 'everything' I meant it dims the entire house just a bit :shock: LOL (not nearly as much as some past wears when I had way more lights, all incandescent)
Re: LED Christmas lights ARRGH!!!!! « Reply #20 on: December 20, 2011, 03:58:01 AM » Author: Medved
And what power do you install? To cause visible "effects" it would have to be in kW range, what is for me hard to imagine with Christmas lights...
kai
Re: LED Christmas lights ARRGH!!!!! « Reply #21 on: December 20, 2011, 07:45:35 PM » Author: kai
Now imagine how they look on 50 Hz :o
Particularly "nice" is the stroboscopic effect when looking around. Fortunately the canteen I regularly visit has retired the old, cheap LED sets they used to put in the windows during the last decade. The flickering, yellow LEDs (indeed ordinary yellow ones) were pretty nasty.
static1701
Scott
Re: LED Christmas lights ARRGH!!!!! « Reply #22 on: December 20, 2011, 08:11:29 PM » Author: static1701
I got my Edison bill today, 6% higher then last month and 43% higher then last year. (Last year I went out of town, so we did not do Christmas lights) So my incandescent Christmas lights are expensive to use but they look so nice :)
I use real incandescent Christmas lights, miniature lights from the 70's, C6's from the 50's and modern C7's and C9's. NO ugly LED's! I don't care what it cost. Real Christmas lights and Preheat Fluorescent!
Re: LED Christmas lights ARRGH!!!!! « Reply #23 on: December 20, 2011, 09:54:00 PM » Author: xmaslightguy
Quote from: Medved
The incandescents are a little over 7,500 bulbs - which runs a bit over 28a / 3,404w
LEDs show less than 3a for alittle over 6,000 bulbs :)
Quote from: kai
Since I can see the 60hz fairly easily ... I bet I could pick up 50hz clear as daylight :o LOL I'd deff want 'full wave' sets there
SeanB~1
Re: LED Christmas lights ARRGH!!!!! « Reply #24 on: December 20, 2011, 11:57:47 PM » Author: SeanB~1
Most of the LED sets here are half wave sets, the only full wave sets I see are those with a chase pattern in them, as they often are run at 12V or so with a small microcontroller doing the switching via some power switches.
Re: LED Christmas lights ARRGH!!!!! « Reply #25 on: December 21, 2011, 04:16:36 AM » Author: Medved
Quote from: Medved
8-) May you post a photo? I thought "normal" installation is few 100' of bulbs, not 1000's. Then indeed, the related electricity bill might be noticeable...
Well, here such lighting is not a tradition, so I have no guess...
Re: LED Christmas lights ARRGH!!!!! « Reply #26 on: December 22, 2011, 12:54:47 AM » Author: xmaslightguy
Quote from: Medved
Yep, cost of power is one of the reasons I have all those lights hooked up so I can flash 'em with the computer. Running that many lights 'steady on' would not only be boring, but the cost would be :o :o
Around here maybe 10% of the houses decorate outside for Christmas (and thats with a few strands on lights), then  there's maybe 1 house in every neighborhood that really decorates
I don't have any photos ready yet, but plan to work on it this weekend (they're gonna go on a somewhat hidden section of my website).
I'll PM (& anyone else who wants to see) you the link once its ready.
Re: LED Christmas lights ARRGH!!!!! « Reply #27 on: December 22, 2011, 05:56:46 AM » Author: Medved
So yours is the "1 house in your neighborhood"? :-)
Re: LED Christmas lights ARRGH!!!!! « Reply #28 on: December 22, 2011, 04:52:46 PM » Author: AngryHorse
LinearSLI/H - What failure happened to the LED string ?
Ash, I think I pulled a wire out somewhere, constantly wrapping them up, then unwrapping them.
I wish I would have put them up and left them now!
Re: LED Christmas lights ARRGH!!!!! « Reply #29 on: December 23, 2011, 04:48:15 AM » Author: Ash
When wrapping them loosely that won't happen
Better, just throw them in a big cardboard box, and take back out next time so that they wont tangle
