Author Topic: It's a 20 watt desk lamp.  (Read 4645 times)
Powell
It's a 20 watt desk lamp. « on: September 09, 2013, 01:17:30 PM » Author: Powell
Yes, the base and vertical supports are wood. Sylvania 20 watt CW with lifeline style etch
http://www.ebay.com/itm/161094994988?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Question, since it is manual start, a F17T8 works fine. Is that going to be hard on the ballast? I discussed this with Funkybulb and we think it should be OK.  I guess I could use a F8T8 but I want other than cool white.
« Last Edit: September 09, 2013, 01:25:17 PM by Powell » Logged
NNNN!
jrmcferren
Re: It's a 20 watt desk lamp. « Reply #1 on: September 09, 2013, 04:16:05 PM » Author: jrmcferren
The FO17T8 lamp is based on the Octron system that the FO32T8 lamps are part of. The Octron system is designed for rapid start operation. The F20 lamp uses more current with a lower voltage the the FO17T8 so the ballast is NOT compatible.
Powell
Re: It's a 20 watt desk lamp. « Reply #2 on: September 09, 2013, 04:38:27 PM » Author: Powell
It starts on preheat manual or starter assisted. It seems properly bright. I guess I should run it in a fixture that I can monitor the ballast with then.
NNNN!
