Author Topic: Say goodbye to GE CFLs  (Read 15593 times)
Re: Say goodbye to GE CFLs « Reply #30 on: April 11, 2016, 03:42:53 AM » Author: Mercurylamps
I'm happy with LED in certain applications, it does have certain uses. I replaced the GU10 halogen downlights with LEDs to reduce heat buildup and lower energy costs and so far they seem to be working out well even though it appears to be a cheap brand. This house has a mixture of CFL and LED lighting in use as tungsten lamps (except halogen) are banned here.
Flurofan96
Re: Say goodbye to GE CFLs « Reply #31 on: April 11, 2016, 05:48:35 PM » Author: Flurofan96
Thats one good thing about GU10 LEDS that they reduce heat buildup, perfect for places/materials where there is a fire risk.
LEDS are best in cold applications such as fridges/freezers (where I often see dim flickering fluoresants that are non HO). One time recently I went to the local Waitress store in Reading and what I saw looked to be a Philips Master LED gone EOLED, but it turned out that the LED half was facing upwards rather than downwards ;D :D
Re: Say goodbye to GE CFLs « Reply #32 on: April 11, 2016, 06:27:42 PM » Author: Ash
The problem in many cases is not as much heat build up, but flammable dust build up. Common insulation materials like sheetrock dont really mind a 12V Halogen. But when there is a layer of dust building up on top of the sheetrock and Halogen spot, then the dust alone can act as the fuel....
Ands dont forget that often the transformers are hidden in the ceiling volume, and get covered with dust over time. They can be no less of a fire risk than the Haklogens, especially if something shorts out....
veryhighonoutput
T12
Re: Say goodbye to GE CFLs « Reply #33 on: June 16, 2016, 08:22:12 AM » Author: veryhighonoutput
That's OK with me they anoy me when I need immediate light no good when in dimmable applications to. I just use in a table lamps.
T12/ t17 there's a reason they made heavy magnetic ballasts
toomanybulbs
Re: Say goodbye to GE CFLs « Reply #34 on: June 18, 2016, 01:16:48 PM » Author: toomanybulbs
ge cfl's never were ge anyway.i had some ge and loa that were indistinguishable with the print covered.
there are a handfull of mfrs that make them for everyone else.
Re: Say goodbye to GE CFLs « Reply #35 on: June 18, 2016, 01:58:48 PM » Author: Ash
Incidentally - OR NOT - the few places around the house where instant full light is needed are the same places where it stays on for less than a minute or up to few minutes normally - Stairs Closets Toilets and so on. There Incandescents are the best solution anyway
Re: Say goodbye to GE CFLs « Reply #36 on: June 18, 2016, 04:44:52 PM » Author: wattMaster
There, CFL make no cents. ;)
Re: Say goodbye to GE CFLs « Reply #37 on: June 18, 2016, 05:21:48 PM » Author: Ash
They do everywhere else
