Author Topic: Ballast Alternatives  (Read 13610 times)
Ballast Alternatives « on: May 23, 2016, 08:57:05 AM » Author: wattMaster
Let's say you want to build a MV fixture.
You can get the lamps and fixture enclosure, But not the ballast. (Currently)
But fluorescent ballasts are legal.
What if you had a ballast/driver that can switch between them?
What are the legal penalties for making a ballast?
What about a magnetic style electronic ballast?
What about importing ballasts? Would they stop you at Customs?
Re: Ballast Alternatives « Reply #1 on: May 23, 2016, 12:53:15 PM » Author: Medved
It is illegal to manyfacture and/or import MV ballasts in the US. Connecting fluorescent ballasts together to run an MV lamp IS "manufacturing" an MV ballast, so it is illegal.
The Act does not distinguish, so if it is supposed to run an MV, it is illegal as well.
By the way what do you mean by "magnetic style electronic ballast"? There is no ballast design, except just a series capacitor (lamp killer) and/or resistor (wasting power), that would not rely to some magnetic component for the main functionality.
If they were really rigorous, yes. But I doubt they would ever do so, unless someone explicitly tell them...
But definitely a heavy item in a luggage when returning from a holiday will rise some suspicion, but more a security related, than really energy related or so.
Re: Ballast Alternatives « Reply #2 on: May 23, 2016, 06:05:25 PM » Author: wattMaster
What I mean about "Magnetic Style Electronic" is essentially a Programmed Start (Electronic Preheating) without the HF driving.
What about a LED driver that "accidentally" has a capability to run MV.
Or if it is not advertised? (Doesn't tell you that it can)
I'm not talking about bringing ballasts in luggage, But what if someone had a cargo ship full of heavy items, And this was one of them?
« Last Edit: May 23, 2016, 06:07:09 PM by wattMaster » Logged
Re: Ballast Alternatives « Reply #3 on: May 23, 2016, 09:22:46 PM » Author: dor123
You can buy an Arlen Pulsestarter or similar electronic starter, to make your magnetic preheat fluorescent fixture, start like a programmed start electronic ballast.
Re: Ballast Alternatives « Reply #4 on: May 24, 2016, 12:19:05 AM » Author: Medved
Well, that would really need quite freaky "accident": LED's need DC feed, MV's AC. MV's exhibit negative resistance sections in their VA curves, so do not allow any significant parallel capacitor. LED's are nice, smooth monotonic (even when steep), so even  a larger capacitor on the output is not big problem (assume the connection between the ballast and lamp is permanent, no switching when the thing is powered).
So it would be really strange LED ballast, if it "happens" to be compatible with MV's, I doubt you will get any conformance certificate for such thing...
Well, it is smuggling like any other. If it is illegal, well definitely it is. If you get caught or if the customs would really care, that is not 100% sure.
Re: Ballast Alternatives « Reply #5 on: May 24, 2016, 11:32:44 AM » Author: wattMaster
I'm not planning to do any of this, But it's confusing.
It's like: "Don't make MV ballasts or else..." And they don't tell you what will happen.
Re: Ballast Alternatives « Reply #6 on: May 24, 2016, 11:33:44 AM » Author: wattMaster
Problem is, Magnetic ballasts are almost extinct.
Re: Ballast Alternatives « Reply #7 on: May 25, 2016, 03:11:25 PM » Author: Medved
The building/fire codes generally require to use only certified components. That means the certification must be valid and cover the way how it is used. So that means the fluorescent ballast certification covers only the use for ballasting the designed fluorescent lamp, for anything else it becomes not certified part (so as it would not had any UL or similar certificate).
And what are the consequences of manufacturing that ballast? You would have to ask some lawyer...
Re: Ballast Alternatives « Reply #8 on: May 26, 2016, 03:50:13 PM » Author: wattMaster
...And realize you just spent enough money to buy a NOS MV ballast.
Re: Ballast Alternatives « Reply #9 on: May 26, 2016, 06:09:11 PM » Author: Medved
Well, that is the best you may do, if you find some. It is present in the US for long time, it is certified to operate an MV, so perfectly legal and acceptable.
Re: Ballast Alternatives « Reply #10 on: May 26, 2016, 10:20:12 PM » Author: wattMaster
Glad a nearby church/art club (I still don't know. The art club has an event called Favo, Try looking it up) has several almost-pure-green MV lamps.
Re: Ballast Alternatives « Reply #11 on: May 27, 2016, 05:20:41 PM » Author: Ash
Think something like this :
 - Pulse MH or (for 250W+) HPS ballast with ignitor
 - Failed ignitor, making it not work, but still let the ballast supply current to the socket. (The failure is intentional, but nobody should know about that...)
 - MV lamp in the socket
This way, the only actual sins are bad QA on the manufacturer's part (for letting the lantern with bad ignitor go through undetected, but it is not forbidden to make crap quality products....), and screwing the wrong lamp into the socket on the user's part, which is not the manufacturer's fault
Re: Ballast Alternatives « Reply #12 on: May 28, 2016, 10:06:33 AM » Author: wattMaster
Nice solution. I'm still trying to figure out why they banned ballasts, But not bulbs.
Re: Ballast Alternatives « Reply #13 on: May 28, 2016, 03:48:28 PM » Author: Ash
You are the government and you want to get rid of Mercury lighting (including mostly Mercury lighting you dont own)
If you ban everything at once, peeps will rise up big backlash, as they only recently bought new (Mercury) lanterns and spent quite a lot of money on them, and suddenly the lamps are banned
So you do it in steps :
1. Ban the lanterns (or ballasts)
2. Wait untill the existing lanterns in use become "old" and "worthless"
3. Ban the lamps and peeps won't complain as much cause they will accept that "it is time for a new lantern anyway"
The lamp ban was planned for the beginning of this year, but eventually they figured out that the environmental impact from Mercury lighting is less than the impact from cutting down the trees to make the paper on which they sign the ban...
Re: Ballast Alternatives « Reply #14 on: May 28, 2016, 05:04:19 PM » Author: wattMaster
Problem is, the lighting collectors (us) don't think it is ready for "better" fixtures.
