Author Topic: What is the Dumbest Thing You've Ever Done Related to Electricals?  (Read 18564 times)
HPS Lover
What is the Dumbest Thing You've Ever Done Related to Electricals? « on: June 01, 2016, 11:26:47 PM » Author: HPS Lover
Hello All:
I was just curious to know: What is the dumbest thing you've ever done (if anything) electrically related, e.g. sticking paper clips in an outlet, or a finger in a light socket.
When I was a kid, I used to LOVE (and am still very fascinated by) electricals, wiring, and such.  Anyways, I sometimes wasn't too smart when it came to what I would do (I was a little kid, young and dumb :), and had my share of moments.  One notable one was the time I found a mini neon glow lamp, without the resistor on it.  I had seen them operate on 120 volt before, but forgot about (or disregarded) the resistor (mistake #1).  Anyways, I took a stripped 120V power cord, plugged it in, and attempted to touch the wires to the bulb.  However, they crossed.  (***POP***!!!!!)  Wires turned black, and tripped the breaker.  :o My mom was PISSED!!!  Yes, I know this was kind of dangerous, but again, I wasn't being to smart.  I was only 10 at the time :)
A second time, I took a miniature lightbulb out of a soldering gun (A vintage half-dead Weller, with a light built in it).  What I didn't realize is that the electromagnetic coil (for the heating element), acted as a transformer.  I wanted to see the bulb lit, and figured it ran directly on 120.  I stuck it into an extension cord, and plugged it in.  Long story short, another pop.  Except the result was a little sweet this time.  There was a satisfying pop, and a bright white flash of light.  The flash was like that of a vintage flash bulb, and the bulb even turned silver inside!  This one was a bit cool, but still likely not the best idea out there!
Anyways, I look forward to hearing what you have to say!
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #1 on: June 02, 2016, 09:22:46 AM » Author: wattMaster
Connect an 5mm LED to a adjustable power supply on the wrong setting, Without any resistors.
Connect an inverter to a 18AH lead acid battery without arc protection.
Another thing kind of related is putting my hand in front of my high power camera flash, And it hurt!
« Last Edit: June 02, 2016, 09:28:32 AM by wattMaster » Logged
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #2 on: June 02, 2016, 10:11:16 AM » Author: dor123
http://www.lighting-gallery.net/gallery/displayimage.php?pos=-68295
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #3 on: June 02, 2016, 10:43:03 AM » Author: wattMaster
Should have done that with capacitors.
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #4 on: June 02, 2016, 10:44:33 AM » Author: Lumex120
1. I had an NOS HPS multi-tap ballast that came out of my m250r2 before I converted it to PSMH.
One day I tried to wire it up but, rather than it powering the lamp, it went "PFFFFFSSHHHH!" and a huge mushroom cloud of smoke erupted out of it like Mount Saint Helens. I immediately unplugged it and opened some windows and put fans in them. I have no idea why this happened, as I am sure it was wired properly. To say the least, it really irritates me that I destroyed a perfectly good new HPS ballast that I was going to use in a county fair project.  :(
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #5 on: June 02, 2016, 10:50:24 AM » Author: wattMaster
Maybe you connected the wrong tap.
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #6 on: June 02, 2016, 10:52:08 AM » Author: Lumex120
Connecting the wrong tap shouldn't make it do what it did... I had the 120v tap connected
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #7 on: June 02, 2016, 06:48:44 PM » Author: wattMaster
Must have been faulty.
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #8 on: June 02, 2016, 06:52:16 PM » Author: Lumex120
The ebay seller where I got the light from said that they came from a flooded warehouse. The box was water damaged and inside the light there was some water damage. maybe that caused it?
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #9 on: June 02, 2016, 07:21:56 PM » Author: wattMaster
Must have not dried out.
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #10 on: June 02, 2016, 07:45:19 PM » Author: Solanaceae
Ouch, sorry for your loss. Also, quoteception. :o
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #11 on: June 02, 2016, 08:15:23 PM » Author: wattMaster
It's not hard to do.
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #12 on: June 02, 2016, 08:16:46 PM » Author: Solanaceae
the quote caption or drying the ballast? To dry the ballast, either use an infrared bulb about 6 in from the ballast or put it outside and flip it every so often over a series of a few sunny days.
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #13 on: June 02, 2016, 08:21:18 PM » Author: wattMaster
Both. Another option for drying the ballast is to put it in a toaster oven for 30 seconds.
Re: What is the Dumbest Thing You've Ever Done Related to Electricals? « Reply #14 on: June 02, 2016, 09:19:59 PM » Author: Solanaceae
or an oven-oven. And stupid fone, i meant to say ception.
