Author Topic: Is it ok to run a 50 watt hps on a 70 watt hps ballast.  (Read 6029 times)
Seth11
13 watt Color CFLs!
Is it ok to run a 50 watt hps on a 70 watt hps ballast. « on: August 23, 2016, 09:28:33 PM » Author: Seth11
I have a wallpack that takes 70 watt hps bulbs but I don't have a 70 watt hps bulb and i don't know if the fixture works or not and I want to know if I can test it with a 50 watt hps bulb?
Say NO to LEDS!!
Re: Is it ok to run a 50 watt hps on a 70 watt hps ballast. « Reply #1 on: August 23, 2016, 10:07:59 PM » Author: Lumex120
Yes, it will be fine and it will have a whiter color.
Re: Is it ok to run a 50 watt hps on a 70 watt hps ballast. « Reply #2 on: August 24, 2016, 02:08:59 AM » Author: dor123
Overdriving HPS lamps can short their lifespan.
Re: Is it ok to run a 50 watt hps on a 70 watt hps ballast. « Reply #3 on: August 26, 2016, 12:37:44 PM » Author: RyanF40T12
Yup, should work, but as stated, will have a bit more of a white hue to it and the life will be significantly reduced.  I am running a few 35 watt HPS on 50 Watt fixtures, though when I tried to run a 35 watt HPS on a 70 watt HPS fixture, I fried the ballast and/or capacitor
