Author Topic: GU24  (Read 6875 times)
GU24 « on: September 10, 2016, 06:00:39 PM » Author: wattMaster
What's the point of GU24 sockets in lamps?
They seem to exist solely for energy efficiency compliance.
Re: GU24 « Reply #1 on: September 10, 2016, 08:00:18 PM » Author: sol
I think you've got it.
Re: GU24 « Reply #2 on: September 10, 2016, 08:19:21 PM » Author: wattMaster
But then why not use the Edison Screw bases, because it's practically the standard?
Re: GU24 « Reply #3 on: September 10, 2016, 08:39:23 PM » Author: sol
Yes but people would simply stick in an incandescent. This particular product is supposed to prevent that.
Re: GU24 « Reply #4 on: September 10, 2016, 09:12:04 PM » Author: wattMaster
So it's maybe for better safety?
RCM442
Re: GU24 « Reply #5 on: September 10, 2016, 09:24:07 PM » Author: RCM442
No, it's only so you can use a certain type of bulb.
Re: GU24 « Reply #6 on: September 10, 2016, 09:40:48 PM » Author: wattMaster
And GU24 to Medium adapters are illegal in California.
Re: GU24 « Reply #7 on: September 11, 2016, 02:35:25 AM » Author: Ash
There would not be much point in banning E26 if the adapters are still allowed, would it ?
Sure you can still get the adapters elsewhere and bring them in, or keep E26 sockets from older installations, or use HID E26 sockets (do they fit GLS lamps ?) (or are they banned too ?)
Re: GU24 « Reply #8 on: September 11, 2016, 10:00:23 PM » Author: wattMaster
But it seems like they are really banned, you would get in big trouble if you get caught using one.
Re: GU24 « Reply #9 on: September 12, 2016, 01:14:41 AM » Author: Ash
Will anyone come to your home and check ?
Re: GU24 « Reply #10 on: September 12, 2016, 08:12:54 AM » Author: wattMaster
It seems like anybody related to the government would report it if they happened to see one being used.
Re: GU24 « Reply #11 on: September 12, 2016, 12:16:21 PM » Author: Ash
And they have the right to come and check because ?
Re: GU24 « Reply #12 on: September 12, 2016, 12:16:56 PM » Author: wattMaster
Maybe for a "home inspection"?
Re: GU24 « Reply #13 on: September 12, 2016, 01:08:08 PM » Author: Ash
Home inspection is a service. The home owner calls home inspection to get a summary of the problems or approval that everything is ok, to check whether there is anything wrong with the house or to show the ok paper to buyers when selling the house. If you call an inspection, remove the adapters..
Re: GU24 « Reply #14 on: September 12, 2016, 06:11:25 PM » Author: joseph_125
The only scenario where GU24 to E26 adapters might cause an issue is when you pull a electrical permit for say new lighting and the code inspector sees them but it's easy to just remove the adapters. If a fixture was like that for my own personal use, I would just change the socket or buy a different fixture.
