Author Topic: Bending tough steel pipe  (Read 4287 times)
Bending tough steel pipe « on: September 12, 2016, 02:48:00 AM » Author: Ash
I found some bent steel pipe, that i'd like to reshape into a bracket for a HID lantern :
So on the end with 2 bends i'd like to get one sharper bend and a longer straight section (instead of the other bend)
Pipe is 1 inch diameter, ~8ft long, 3mm wall thickness. I tried by sticking it into a hole in a concrete wall and pulling, it didnt move at all
How i bend this ?
FGS
Rory Mercury!
Re: Bending tough steel pipe « Reply #1 on: September 12, 2016, 06:08:41 AM » Author: FGS
You'll need this tool and a LOT of muscle! What you have is rigid conduit. I've done 1/2" rigid and it was hard. Can't imagine 1" one.
That or borrow/rent a powered conduit bender from an electrician in your area.
Re: Bending tough steel pipe « Reply #2 on: September 12, 2016, 07:07:41 AM » Author: Ash
This is a water pipe originally, not electrical conduit. Thing is, round (pipe) steel conduit have not been used here for electrical installations since the 70s, and they dont bend water pipes (they use them straight and with elbows where needed), so nobody i know have such tool
Re: Bending tough steel pipe « Reply #3 on: September 12, 2016, 08:16:00 AM » Author: wattMaster
Maybe a way to bend it is to heat it enough with a propane torch to where it will bend easier, but not melt.
Re: Bending tough steel pipe « Reply #4 on: September 12, 2016, 08:34:40 AM » Author: Lumex120
I have tried that and found out the hard way that it destroys the pipe no matter what. I think the best thing to do here is use the conduit bender.
Re: Bending tough steel pipe « Reply #5 on: September 12, 2016, 06:13:59 PM » Author: joseph_125
Yeah, I find bending pipe with just a torch tends to kink the pipe at the bend so I would either use the conduit bender (powered if available) or use a bending spring if you have to use a torch to bend.
A muffler shop should have a powered pipe bender that might be able to bend that pipe if you can't find a conduit bender
« Last Edit: September 12, 2016, 06:16:07 PM by joseph_125 » Logged
