Author Topic: What portable fans do you use  (Read 18967 times)
F96T12 DD VHO
Just chilling I guess
What portable fans do you use « on: March 21, 2018, 12:14:24 PM » Author: F96T12 DD VHO
When I say portable I mean standing, tower, industrial, desk, or just some fan from Lasko or something
I use a 20" Lasko High Velocity fan it's rated 150W and each level goes like this for the wattages 150,100,50
Re: What portable fans do you use « Reply #1 on: March 21, 2018, 06:02:12 PM » Author: Cole D.
I usually use either a 12" Emerson oscillating fan from 1953 that has 4 blades or a 12" Emerson oscillating fan from 1918 with 6 blades or a 20" GE box fan that has 5 blades, those are my favorites.
LampLover
120/240VAC @ 60HZ
Re: What portable fans do you use « Reply #2 on: March 21, 2018, 06:20:12 PM » Author: LampLover
Nothing beats an old US made all metal fan ;D
I had a Patton High Velocity Air Circulator it was the 18" model but unfortunately the motor seized so I got rid of it
I still have a vintage fan in normal use though
I have an Eskimo 20" (McGraw-Edison) box fan Model 20139 which is the premium three speed model with the Venturi housing around the blades so it directs more air forward
The Eskimo fan was a trash find and works perfectly
LED Free Zone!
Re: What portable fans do you use « Reply #3 on: March 21, 2018, 06:43:53 PM » Author: Mandolin Girl
We have an 18" floor standing fan that didn't get any use at all last year as it didn't get warm enough.  :(
Re: What portable fans do you use « Reply #4 on: March 21, 2018, 07:19:06 PM » Author: Mercurylamps
My house has ceiling fans throughout and I also have a few pedestal fans in use. The nearest pedestal fan is branded "Moretti" and is a home brand of Bunnings in Australia.
Re: What portable fans do you use ? « Reply #5 on: March 21, 2018, 07:50:09 PM » Author: sol
I use a Rowenta Turbo Silence Desk Fan in pretty much 24/7 use to try to equalize the temperature between the two floors of my house. It is pretty much dead silent on speed 1, but somewhat noisier on faster speeds. The motor is silent, the noise is mostly from the air rushing in the grilles and between the blades.
I used hardware store brand fans in the past for this same purpose, and they would last about 1 year before becoming very noisy due to worn bearings. This one has been going for about 2 years with no noticeable noise increase.
I admire old all metal fans that are built to last, but I fear that they might be too noisy for my applications.
Re: What portable fans do you use « Reply #6 on: March 24, 2018, 02:50:42 PM » Author: Cole D.
That Rowenta is interesting, I like the clear blades. Actually some of the older metal fans are very quiet. Especially the ones with a deep blade pitch. My Emerson from 1953, you can barely hear on low and it still puts out a lot of air at any speed.
Re: What portable fans do you use « Reply #7 on: March 24, 2018, 07:56:16 PM » Author: sol
Actually the blades are transparent light blue. I quite like a fan with blue blades, I might try to get a vintage one on eBay someday...
It's nice to know the old metal ones can be quiet, provided nothing has bent a blade or so.
Re: What portable fans do you use « Reply #8 on: March 24, 2018, 11:19:39 PM » Author: Cole D.
I know the ones you mean, the Galaxy and Lasko ones were some. My grandma had one and I wished I had kept it.
I do have one blue bladed fan with the plastic blades but the rest of the fan is actually metal.
CEB1993
Camden
Camdenburns93
Re: What portable fans do you use « Reply #9 on: March 25, 2018, 06:15:23 PM » Author: CEB1993
I have two 12-inch Comfort Zone fans, one at work, and one on my bedside table at home.  I use a 16-inch Lasko floor fan at the lake house.  All three fans are three speed.  When it's warmer outside, I like the gentle "whoosh" of a table or floor fan while I'm sleeping.
Stop the lamp bans!
rapidstart_12
@rs12official
Re: What portable fans do you use « Reply #10 on: July 01, 2025, 10:18:06 AM » Author: rapidstart_12
Lasko Galaxy (Sanyo) 2150 blue-bladed 12-inch oscillating fan from approx. 1975 by my bedside. I use this unit all night every night from around March to November.
Re: What portable fans do you use « Reply #11 on: July 01, 2025, 11:24:47 AM » Author: rjluna2
I used to have bedside fan at My Nightstand, but I had to get rid of it due it no longer functioning.
Laurens
Re: What portable fans do you use « Reply #12 on: July 01, 2025, 12:47:52 PM » Author: Laurens
I use this Wisa fan, which is between 90 and 100 years old. You have to fill the grease cups with oil every so often.
I got it from an uncle as a kid. Didn't use it much back then.
When i actually started to use it, i noticed the speed would slowly sag and it would get quite hot. Turns out the winding varnish was charred in places, and electrically leaky. Many years later (2 years ago) i rewound the motor (4 coils of about 1500 turns!) and re-painted it.
Finally i had to make a new replica cage. The old cage was made from aluminium and had a lot of broken bits. Tried to fix it as a kid but didn't manage to and probably just threw it away. The new one i made from thin brass pipe. I hope it holds up to the vibration!
Once i paint it aluminium grey it will be a pretty faithful replica, only it seems like i made it a bit too big. Oh well. I'm not gonna make another one, it's a lot of hard work.
The cage is not actually mounted to the fan yet, i need to figure out how it was attached. I can tell you it hurts if you accidentally touch the spinning metal blade!
LightsoftheWest
SRP for life.
streetlightian
Re: What portable fans do you use « Reply #13 on: July 04, 2025, 02:58:16 AM » Author: LightsoftheWest
I have a Vornado 460 that I'm planning on taking to college. Sure, it's not old, but given the quality of Vornado products, I'm sure it'll last a long time.
LG's North American luminaire identification specialist
beatoven
Re: What portable fans do you use « Reply #14 on: July 15, 2025, 03:44:13 AM » Author: beatoven
Quite a few, due to a lack of AC, but this battered Penncrest has the most character of them all. Per my uncle, it has spent every summer since about 1970 in this spot, circulating air through the den and kitchen. Due to worn out bearings, it can no longer be used on the high setting, but will rattle away happily all day on the lower ones.
