Author Topic: No more than 900 lumens...  (Read 5045 times)
No more than 900 lumens... « on: January 11, 2019, 12:00:24 AM » Author: xmaslightguy
900 Lumens or less, No lights over 3000k, and bulbs must be within a fixture that aims light downward plus obscures view of the bulb.
That's the basics of  an  ordinance that one of the towns (Boulder) here in Colorado has put into effect for outdoor lighting on single-family homes.
There are requirements for rental & commercial buildings as well that vary by size & type of business.
To me 900-lm would not be near bright enough...
Re: No more than 900 lumens... « Reply #1 on: January 11, 2019, 12:46:10 AM » Author: dor123
I think these are regulations against light pollution.
Re: No more than 900 lumens... « Reply #2 on: January 11, 2019, 08:50:55 AM » Author: funkybulb
do they run around with a light meter and go by color of bulbs?
Re: No more than 900 lumens... « Reply #3 on: January 11, 2019, 02:45:31 PM » Author: Medved
I would guess after getting a complaint they will will check that...
Otherwise I doubt...
Re: No more than 900 lumens... « Reply #4 on: January 11, 2019, 06:39:49 PM » Author: xmaslightguy
Quote from: funkybulb
They do have a light meter and can check...but like Medved said, I doubt they'll go around checking people's houses, unless someone complains.
Quote from: dor123
Its part of a larger batch of energy efficiency standards/regulations which that town passed, but yep this particular one is mainly for light pollution.
Re: No more than 900 lumens... « Reply #5 on: January 11, 2019, 09:02:56 PM » Author: sol
It is most likely also aimed at contractors who build entire neighbourhoods. The inspector will probably have a problem with glare bombs. Otherwise it provides a mechanism for the city should complaints be made about lighting, like Medved mentionned.
Re: No more than 900 lumens... « Reply #6 on: January 11, 2019, 11:09:42 PM » Author: dor123
Lot of people here in Kiryat Ata and Haifa, putting eBay grade LED floodlights on their houses, which are glare bombs and contribute to the light pollution.
My Philips ML 160W SBMV produces 3200lm average which is slightly lower than a 80W MV lamp (3600lm for the Philips HPL-N 80W) and the American 100W/DX mercury lamp, which is a reasonable level for household outdoor lighting. 900lm is enough for indoor use but no enough for outdoor use.
With LED lighting, there are three other causes for light pollution: Inferior optics compared to conventional lighting, very high level of glare compared to the low lux levels on the ground and the low lumens output, and the spectrum of the common white LED. So with LED, even a 900lm LED floodlight or fixture is enough to worsen the light pollution.
