Author Topic: mission code named "pain in the arse" begins tonight.  (Read 6385 times)
mission code named "pain in the arse" begins tonight. « on: August 11, 2019, 03:01:20 PM » Author: HomeBrewLamps
gonna save:
6 SYLVANIA GTE F40 Daylight lamps
3 WESTINGHOUSE F40 Cool white Blackenders
8 PGT17 tubes i think both 6 foot and 8 foot. or whatever the powergroove t17 equivalent is...
1 or 2 construction flashers.
I may or may not also make a side stop to save a Westinghouse econowatt T17 retrofit lamp (one of those T12 lamps with T17 mogul bipin base)
all on a bicycle. without a trailer. and the power grooves are 10 miles away lol. the daylights and westy's are closer (3 miles) but hauling any bundle of tubes farther than 50 feet is a pain in the butt lol.
i will do it though, because if I dont they'll certainly be gone for good. probably end up smashed by some dumb kid with a rock.
« Last Edit: August 11, 2019, 03:08:57 PM by HomeBrewLamps » Logged
Edmund Ironside
Re: mission code named "pain in the arse" begins tonight. « Reply #1 on: August 11, 2019, 03:30:10 PM » Author: Edmund Ironside
I wish you the best of luck!
Made in Sweden
Re: mission code named "pain in the arse" begins tonight. « Reply #2 on: August 11, 2019, 09:49:05 PM » Author: wide-lite 1000
Good luck man !!! Remember to take tape to bundle them with . And maybe some form of padding so one end can possibly rest on the handlebars.
Edmund Ironside
Re: mission code named "pain in the arse" begins tonight. « Reply #3 on: August 13, 2019, 04:36:10 PM » Author: Edmund Ironside
Did you manage to save any lamps?
Made in Sweden
Re: mission code named "pain in the arse" begins tonight. « Reply #4 on: August 17, 2019, 08:57:10 PM » Author: HomeBrewLamps
I completed it partially last night and today.... All that's left is the power grooves... Which are the biggest trophy of all for this particular mission... Although I think I'll add a couple high bay lights to this particular mission... I believe theyre 50s or 60s vintage... They're must saves!
Re: mission code named "pain in the arse" begins tonight. « Reply #5 on: August 23, 2019, 07:28:31 AM » Author: HomeBrewLamps
Completed.
Re: mission code named "pain in the arse" begins tonight. « Reply #6 on: August 23, 2019, 09:43:53 PM » Author: wide-lite 1000
Completed.
 Did you get the old hi-bays also ?
Re: mission code named "pain in the arse" begins tonight. « Reply #7 on: August 25, 2019, 07:51:54 PM » Author: HomeBrewLamps
those weren't part of the original objective... However I will be retrieving them soon!
Re: mission code named "pain in the arse" begins tonight. « Reply #8 on: August 30, 2019, 09:54:15 PM » Author: HomeBrewLamps
I got the highbays home!
Re: mission code named "pain in the arse" begins tonight. « Reply #9 on: August 30, 2019, 10:37:50 PM » Author: wide-lite 1000
Awesome ! I just looked at the pictures !
