Author Topic: Looking for clear SBMV  (Read 5113 times)
RadiantMV
Looking for clear SBMV « on: May 03, 2020, 04:05:36 PM » Author: RadiantMV
Im looking for a clear self ballasted mercury vapor bulb, any wattage or voltage will do. Thanks!
Mr. Orthosilicate
Re: Looking for clear SBMV « Reply #1 on: May 03, 2020, 10:38:03 PM » Author: Mr. Orthosilicate
Here’s a 250w one:
https://www.ebay.com/itm/PREMIUM-QUALITY-SELF-BALLASTED-METAL-HALIDE-LAMP-250W-E40-5000K-HYDROPONICS/282148018706?hash=item41b1551a12:g:w0gAAOSwd0BVuRxf
And here’s a 400w one:
https://www.ebay.com/itm/PREMIUM-QUALITY-SELF-BALLASTED-METAL-HALIDE-LAMP-400W-E40-5000K-HYDROPONICS/282148014398?hash=item41b155093e:g:c2UAAOSwPcVVuSIJ
Pay no attention to the fact they say that they are metal halide lamps; they are some random chinese bulb that is incorrectly labeled. Several members here have them and can confirm that they are indeed self ballasted mercury lamps.
Re: Looking for clear SBMV « Reply #2 on: May 03, 2020, 10:40:28 PM » Author: Lumex120
Those lamps you linked are 240v which could be problematic.
RadiantMV
Re: Looking for clear SBMV « Reply #3 on: May 04, 2020, 12:14:02 PM » Author: RadiantMV
Here’s a 250w one:
I've seen those, but I'm not sure if they would work for me since they're hybrid/blended halogen bulbs
Re: Looking for clear SBMV « Reply #4 on: May 04, 2020, 12:52:27 PM » Author: sol
All SBMV lamps are hybrid/blended because the tungsten filament is the ballasting element. Mercury arc tubes need a ballast which can be reactive (core and coil) or resistive (tungsten filament).
If you’re looking for pure MV light, then you need a clear standard MV lamp and an external ballast.
RadiantMV
Re: Looking for clear SBMV « Reply #5 on: May 04, 2020, 02:00:23 PM » Author: RadiantMV
Are even the older models blended? Like the fluomerics and iwasakis?
Re: Looking for clear SBMV « Reply #6 on: May 04, 2020, 02:07:14 PM » Author: sol
Yes, all self ballasted mercury lamps (those that run directly on mains) are blended because there needs to be a filament to act as a ballast. The only exception are the self-ballasted metal halide which have a small electronic ballast built in. However, those are not what you're after...
There is no escaping a ballast : the arc tube will destroy itself in a fraction of a second if there is no ballast. Either the ballast is a filament such as SBMV or a standard ballast separate from the lamp.
I believe most people who collect insects at night prefer a standard clear mercury vapour lamp, which of course requires a separate ballast.
RadiantMV
Re: Looking for clear SBMV « Reply #7 on: May 04, 2020, 03:41:28 PM » Author: RadiantMV
Okay thanks. I'll probably buy some of those then though I'm still looking for other models, my favorite being the fluomeric 750w though those are very rare. Also a lot of insect collectors do use SBMV and not regular ballast.
« Last Edit: May 04, 2020, 03:43:03 PM by MothTrapper16 » Logged
