Author Topic: Voltage variating between 220, 230 and 240 heree.  (Read 14897 times)
Re: Voltage variating between 220, 230 and 240 heree. « Reply #30 on: September 03, 2020, 04:51:40 PM » Author: Ash
A module called "Granite" used to be made by Belarus company Nootechnika, meant for permanent wiring into the building's wiring and tucking into a connection box or so, for soft starting GLS and Halogen lamps. The module is basically a dimmer with a controller that ramps it up from 0 to max over a split second, every time power is applied to it
