Author Topic: Anyone making DIY HID fixtures or converting incandescent fixtures to HID?  (Read 3395 times)
UChBXesrxSalDTp79uMtfDvA
Anyone making DIY HID fixtures or converting incandescent fixtures to HID? « on: October 17, 2020, 03:59:06 AM » Author: WorldwideHIDCollectorUSA
I would love to know if anyone besides HomeBrewLamps, streetlight98, and DaveMan has made any DIY HID fixtures or converted normally incandescent fixtures to HID?
Re: Anyone making DIY HID fixtures or converting incandescent fixtures to HID? « Reply #1 on: October 17, 2020, 05:45:32 AM » Author: Medved
Converted 300W linear halogen torchiere to 70W double ended CMH, include 2-way dimmable ballast (ballast made of two F36T8 and one PL-S choke all in parallel, with one of the F36 ones disconnected for the reduced power setting; ballasts in the base instead of the original stability weight, igniter in the head close to the lamp).
And then the "obligatory" linear halogen flood conversion to the same 70W linear MH, with a remote ballast mounted in an old PC power supply box...
Re: Anyone making DIY HID fixtures or converting incandescent fixtures to HID? « Reply #2 on: October 17, 2020, 09:19:45 AM » Author: sol
I have done this as well. Mainly table lamps for now, with one exterior post light. Others to come, but I have no idea when...
Xytrell
Re: Anyone making DIY HID fixtures or converting incandescent fixtures to HID? « Reply #3 on: October 17, 2020, 11:12:53 AM » Author: Xytrell
I do this all the time. I've got several floor lamps, a few wall-lights, and even a chandelier. As I understand it, if it has some sort of pulse-start, the ballast should be close by. However, I've had the ballast 10 feet away from a 150W metal halide and HPS before though with no (obvious) starting issues.
Re: Anyone making DIY HID fixtures or converting incandescent fixtures to HID? « Reply #4 on: October 17, 2020, 02:00:49 PM » Author: wide-lite 1000
I have this one  :  https://www.lighting-gallery.net/gallery/displayimage.php?album=5198&pos=184&pid=158364 it's remote ballasted with a F-can style ballast mounted in the garage . It's running a clear 50w MV .
Re: Anyone making DIY HID fixtures or converting incandescent fixtures to HID? « Reply #5 on: October 17, 2020, 02:27:01 PM » Author: AngryHorse
I made this from an old emergency light, https://www.lighting-gallery.net/gallery/displayimage.php?pos=-68604, fellow member Andy now has it on the side of his garage!  :)
Re: Anyone making DIY HID fixtures or converting incandescent fixtures to HID? « Reply #6 on: October 17, 2020, 04:05:07 PM » Author: Ash
I have installed a 70W SON E/I in a plain pendant in a commune room (with the ballast wired remotely)
Also converted some Incandescent luminaires to PL, and once a HID lantern converted also to PL for use as an indoors lamp
