Author Topic: What did you do today lighting wise?  (Read 1300768 times)
SussexEuroSOX
Fox - The Shadow Rhombaloux
Re: What did you do today lighting wise? « Reply #1800 on: January 25, 2026, 02:05:02 AM » Author: SussexEuroSOX
I put a leaning sign light back up
ACEC - Ateliers de Constructions Electriques de Charleroi
The Master of Belgian Street lights
Dream is for an ACEC lantern
Also interested in French, Spanish, German, Polish, Australian and Italian street lights.
DoNotLeaveTheLight
https://www.lighting-gallery.net/index.php?topic=18978.0 🇧🇪
Re: What did you do today lighting wise? « Reply #1801 on: February 07, 2026, 12:48:40 AM » Author: xmaslightguy
Replaced an EOL F20 plant/aquarium lamp (and the starter) in one of my aquarium lights.
Laurens
Re: What did you do today lighting wise? « Reply #1802 on: February 10, 2026, 01:12:02 AM » Author: Laurens
I saw this video: https://i.imgur.com/lL3130r.mp4
I wonder if the guy even knows that the mercury, as small as the amount is, sticks to the phosphor and glass.
Re: What did you do today lighting wise? « Reply #1803 on: February 10, 2026, 10:23:19 PM » Author: xmaslightguy
Last few 'light things I did:
On the weekend...
Replaced a WW F20 that went EOL.
Yesterday...
Reorganized a portion of my fluorescent lamps
Today...
Installed this F20 fixture
thelightingman
Nothin beats good ol MV, MH, and HPS
Re: What did you do today lighting wise? « Reply #1804 on: February 11, 2026, 02:15:14 AM » Author: thelightingman
Back on Monday I got a 175w MV shoebox light that I'm currently in the process of repainting and restoring, the place I got it from has a parking lot full of them and the guys working on changing them out gave me one (and seemed to be willing to give me more  8;) )
I might go back and see if I can get some of the floodlights that's there as well along with another one (or 2) of the shoebox lights cause why not  ::)
(I've done a lot of lighting related things recently, just haven't had the time to post about any of it)
I think HPS, MV, and MH rule! :mv: :mvc: :hps: :emh: Fluorescent lights are also awesome!
LED's just kinda exist...
rapidstart_12
@rs12official
Re: What did you do today lighting wise? « Reply #1805 on: February 14, 2026, 07:23:27 PM » Author: rapidstart_12
Tested, cleaned, and serviced a number of 1987-1988 Lithonia Lighting 2xF40T12 fluorescent strip lights so that I can install them in the lighting workshop next weekend. The fixtures were acquired from FaceBook MarketPlace back in November.
The fixtures have a mix of ballasts, mostly Universal 446-LR-TC-Ps, a couple Advance R-2S40-TPs, and one has a GE electronic ballast which will likely be replaced. One fixture did not come with a ballast. All ballasts seem to work just fine, so I will go ahead and install the fixtures. A couple of lampholders needed to be replaced.
For cleaning, I disassembled the fixtures and pressure washed the housings, then I went back in with some wipes and put the fixtures back together. Took several hours to get them all done, but I’m glad they are all finished now. There is some rust on a few of the fixtures, but I won’t worry about that for the time being.
rapidstart_12
@rs12official
Re: What did you do today lighting wise? « Reply #1806 on: February 22, 2026, 08:54:31 PM » Author: rapidstart_12
Installed some fluorescent strip lights in my lighting workshop today! Fixtures are all 1988 Lithonia Lighting C240 strip lights. Lamps are a mix of 34W halophosphate CW and 40W triphosphor 4100K, all different brands. Ballasts are a mix of Advance R-2S40-TP and Universal 446-LR-TC-P. I quite like the way this turned out, it has a very oldschool vibe to it.. Lighting is much more intense and even than the single shoplite that was there before. Eventually, there will be two switches controlling two sets of fixtures, but for now, everything is plugged into an outlet until I can get a new run of wiring installed for switches.
Maxim
Re: What did you do today lighting wise? « Reply #1807 on: February 22, 2026, 10:13:52 PM » Author: Maxim
@rapidstart_12 — couple of questions: where did you source these from, and how are they switched on/off?
Superb install!
rapidstart_12
@rs12official
Re: What did you do today lighting wise? « Reply #1808 on: February 22, 2026, 10:37:02 PM » Author: rapidstart_12
@Maxim - Thank you for the feedback!
As far as sourcing goes, I got this lot of fixtures from facebook marketplace after waiting over a year and a half for a decent listing in my area to become available. You’d think F40T12 strip lights would be a pretty easily obtained fixture, but to get so many matching vintage ones is surprisingly difficult. The listing included the seven 1988 Lithonia C240s used in the install along with two similar 1987 units, a cheap shoplight, and a newer wraparound with broken diffuser, plus a bunch of newer and older lamps.
For switching, I just have the fixtures plugged into a small switch adapter thingy that plugs into an outlet. This is temporary until I can get a proper wiring setup installed (was planning to install the fixtures after that was done but decided to do them before). The fixtures are internally wired for two switches, but everything it just tied to one plug for the moment.
Maxim
Re: What did you do today lighting wise? « Reply #1809 on: February 22, 2026, 11:50:09 PM » Author: Maxim
@rapidstart_12 — I see. Looks very nicely done. Now I await the "final" setup pics.  ;D
suzukir122
suzukir123
Re: What did you do today lighting wise? « Reply #1810 on: February 28, 2026, 06:24:03 PM » Author: suzukir122
@rapidstart_12, very, very epic score on those 446-LR-TC-P Universal ballasts in those fixtures. Therm-O-Matic? Therm-O-Matic X??
Those are some of the best HPF Magnetic Rapid Start ballasts one could possibly purchase. Lights up lamps very nicely.
Also, I HIGHLY agree with you that finding matching vintage fixtures is difficult, due to my search of all 11 of my living room fixtures
almost a year ago. My fixtures in my upstairs loft use to be LED ready fixtures, before I converted them to magnetic Rapid Start/T12.
Anyways, keep at it with the set up @rapidstart_12,... post that final set up pic when you get the chance.
We're keeping it 446-LR-TC-P over here as well... for my lighting wise event of the day, I just bought a Therm-O-Matic HPF Rapid Start ballast
from Ebay. This ballast will replace the ballast inside of the middle fixture of the five fixtures in my upstairs loft. The ballast that I'm
replacing has the same part number, but it is not the Therm-O-Matic version. I don't think it's the ballast... could be the lamp, but: the lamp
facing outward appears to be a tad bit dimmer than the other lamp in series with it, and the other lamps around it. It's really not that noticeable
and I've been debating on replacing that ballast for several months now, but I've finally given in. We will see if that Therm-O-Matic ballast will
change things. Doubtful, but it's worth a try. Also, once I replace this ballast, all five fixtures upstairs would have Therm-O-Matic ballasts in them,
3 of which are Therm-O-Matic X... unlike most of the fixtures downstairs. All the fixtures downstairs, although still 446-LR-TC-P, aren't the
Therm-O-Matic versions.
Interests:
suzukir122
suzukir123
Re: What did you do today lighting wise? « Reply #1811 on: April 12, 2026, 11:53:02 AM » Author: suzukir122
Just bought two F20T12 single lamp fixtures from Ebay. They're both low power factor Trigger Start ballasted, so I assume I've got to change out the "cut off" sockets in order to run High Power Factor Trigger Start ballasts in them, so I'm about to purchase four standard sockets as well.
These fixtures will be used in light tables I'm about to buy for my upstairs loft... I'll be using my cold temp GE Bonus-Line Trigger Start ballasts in both fixtures. Since I've never used 20w lamps on those ballasts yet, it'd be interesting to see how those ballasts perform with 20w lamps.
Interests:
Re: What did you do today lighting wise? « Reply #1812 on: April 12, 2026, 12:57:05 PM » Author: xmaslightguy
Last light-related thing I did was to install a 2xF17/F20 striplight in the garage(currently running a pair of F20's).
Also replaced a EOL F96 slimline lamp there while I had the ladder out.
Re: What did you do today lighting wise? « Reply #1813 on: April 12, 2026, 12:59:56 PM » Author: xmaslightguy
Quote from: suzukir122
You can actually just take the 2 white wires on the side of the lampholder where the cutout thingie is and connect them together...then you have a "normal" lampholder. .lol.
suzukir122
suzukir123
Re: What did you do today lighting wise? « Reply #1814 on: April 12, 2026, 01:36:41 PM » Author: suzukir122
 :wndr:.....  :lol:... I don't know as much about the LPF Rapid or Trigger Start single lamp ballasts, so I don't know as much in terms of
the wiring or the sockets. I've already went ahead and bought sockets. Not much money lost there, since I'm about to sell my sportcar. lol
Interests:
