Author Topic: Where can I get good terminal blocks?  (Read 13955 times)
fluorescent lover 40
Where can I get good terminal blocks? « on: December 25, 2018, 01:33:25 AM » Author: fluorescent lover 40
Where's the best place I can get terminal blocks? I want to upgrade to terminal blocks and want to get good quality but cheap ones.
Re: Where can I get good terminal blocks? « Reply #1 on: November 27, 2019, 03:27:48 PM » Author: HomeBrewLamps
I'm curious of this as well.
Re: Where can I get good terminal blocks? « Reply #2 on: November 27, 2019, 05:15:48 PM » Author: sox35
What type are you looking for..? The type I use most often are these, but I know they're not common your side of the water.
Re: Where can I get good terminal blocks? « Reply #3 on: November 28, 2019, 03:06:06 AM » Author: joseph_125
I see them a lot in stores that sell electronic components (like individual resistors, capacitors, LEDs etc). So if you have one in your city, pay them a visit since they'll probably have it.
Failing that, I guess eBay, Mouser or Digikey will have pretty much every kind of terminal block you could imagine.
Re: Where can I get good terminal blocks? « Reply #4 on: January 08, 2020, 11:50:48 AM » Author: Mandolin Girl
I have found these on the UK eBay that should do the job.  :)
We'll be ordering a load as soon as the finances recover from buying lots of lovely SOX lamps  ;D
« Last Edit: January 08, 2020, 02:04:43 PM by Mandolin Girl » Logged
Re: Where can I get good terminal blocks? « Reply #5 on: January 08, 2020, 04:37:59 PM » Author: AngryHorse
Nah, terminal blocks are out dated tech now, WAGO connectors are the way forward  ;D
Re: Where can I get good terminal blocks? « Reply #6 on: January 08, 2020, 04:38:59 PM » Author: sox35
I worry about you sometimes, I really do  :D
Tha SOX MADMANNN
Re: Where can I get good terminal blocks? « Reply #7 on: January 09, 2020, 08:52:25 PM » Author: 589
Just got some myself, they’re great! I just installed some Lithonia LED 4’ strip lights at a local thrift shop and they were filled with wago lev-r-nuts. It was a great installation experience!
:lps:
Re: Where can I get good terminal blocks? « Reply #8 on: January 10, 2020, 07:53:25 AM » Author: sox35
Still prefer good old fashioned choc blocks  ;D
Re: Where can I get good terminal blocks? « Reply #9 on: January 10, 2020, 08:56:23 AM » Author: fluorescent lover 40
Hey, it's your choice! Nobody's going to judge you for that.
Re: Where can I get good terminal blocks? « Reply #10 on: January 10, 2020, 09:12:10 AM » Author: fluorescent lover 40
What size and voltage rating?
Standard size and rated for 120v.
Re: Where can I get good terminal blocks? « Reply #11 on: January 10, 2020, 10:13:03 AM » Author: AngryHorse
Sparkies laugh at you now if you’re still using ‘chock blocks’  ;D WAGOs are so much easier, faster and safer to make connections in, of course you still have to get the correct rating for the job 8)
Re: Where can I get good terminal blocks? « Reply #12 on: January 10, 2020, 10:27:08 AM » Author: Mandolin Girl
They can laugh all they like, I use what I'm used to and what do the job for me.
Re: Where can I get good terminal blocks? « Reply #13 on: January 10, 2020, 10:41:14 AM » Author: Mandolin Girl
I've looked at the WAGO connectors, and I can't see any way of fastening them to a lamp board permanently which is what we need.  :-\
So we will stick with traditional choc blocs. :)
Tha SOX MADMANNN
Re: Where can I get good terminal blocks? « Reply #14 on: January 13, 2020, 10:34:44 PM » Author: 589
I was just talking with a local commercial elechicken Sunday and he has never seen wagos before and almost. We still use wire nuts and etape round these parts. He was telling me about a connection I found on a 40 year old building, bare crimp sleeve and etape around that, not to mention flathead only hardware. Apparently that was used before wire nuts came into play. I don’t like wire nuts but alas it’s the standard here.
:lps:
